Hi
I have pressing need for the driving CS5532ASZ in the AVR microcontroller with SPI interface.
Please help me for writhing c code program by considering the following:
1- Sampling frequency is constant (such as 100 HZ)
2- Analog signal is -2.5 to +2.5 volt
3- Used 2 channels of CS5532ASZ for sampling
Reading analog signal should be in the constant time periods ( such as 200ms or 1s ) that Commands is taken through the AVR microcontroller. After a series applied math, digital values are displayed on the LCD.
If possible please help me with codes sample related this project
Thank you so much.</SPAN></SPAN>
