A/D Converter
Discussion in 'Homework Help' started by hncelectronics123, Jun 4, 2008.
  1. hncelectronics123
    May 23, 2008
    10
    Hello again Guys
    Another question id like to ask is;
    I have an output from an analogue device of 0.699mV
    Using An 8bit A/D converter work out the output.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    What is the ADC range? Is the ADC linear or non-linear?
    Dave
  3. hncelectronics123
    May 23, 2008
    10
    The ADC is Linear yes.
    The only other information i have on it is
    Number of bits = 8
    Input to achieve ful scale output = 4 volts
    Does this help?
  4. hncelectronics123
    May 23, 2008
    10
    Ok i have worked out the Resolution of the A/D converter.
    8 bits = 256 codes
    full scale output = 4v
    so....... 4v/256codes = 15.62mV
    Can anybody work out the final output of the A/D converter if the input is 0.699mV
    Thanks in advance
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    In you first post you say 0.699V and in the last 0.699mV.
    With 0.699V ( that is 699 mV ).
    Per step you calculated 4 V / 256 = 15.625 mV
    If you divide 699 mV / 15.625 mV you will get 44.736.
    Depending on the accuracy you will get 44 or 45 as a digital value.
    Greetings,
    Bertus
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Yes that is the ADC range.
    15.62mV is correct as the resolution.
    Are you sure you want to know the output for 0.699mV? 0.699mV is considerably less than the 15.62mV resolution of the ADC; therefore an input of 0.669mV would not register a reading at the output, i.e. the output would be 00000000
    If it is 0.699V and not 0.699mV, then the answer is as bertus has explained of 45 (in base 10) or 00101101 as an 8-bit binary output.
    Dave
  7. hncelectronics123
    May 23, 2008
    10
    Thanks alot Yeah my mistake with the mv, v thing. been along day.
    So, lets say that the output of the analogue/digital converter is 45.
    I understand that this is the output but can this be displayed in a binary format, Such as 11010110
    Thanks very much
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    No problem, thanks for clearing it up.
    45 (decimal) is 00101101 (binary) - this is the 8-bit output of the ADC for an input voltage of 0.699V.
    Dave
  9. hncelectronics123
    May 23, 2008
    10
    Many thanks for all your help!!!!!!
    Sorry for the mistake, you are right with 0.699v.
    Once again thank you very much
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    No problems. Lets us know if you have any further queries.
    Dave
