A/D conversion using the pic 16f877
Discussion in 'Embedded Systems and Microcontrollers' started by jwebbo, Jul 25, 2010.
  1. jwebbo
    Jul 23, 2010
    Hi everyone,i am seeking your help.
    I am trying to program the PIC 16f877 microcontroller to accept multiple analog inputs and give readouts on the 7-seg display. the conversion is of a 10 bit resolution. my problems are that i cannot seem to get the pic to correctly display the adresh and adresl registers simultaneously. when i display the adresl anone,it is ok because i have tested it using the leds.CAN someone please help me with the codes to display both registers. in addition,i do not know how to measure multiple inputs.
    lastly,when i send my codes to the lcd, nothing is displayed. can anyone help me with the correct assembly codes for this pic (16f877).
    IF ANYONE HAS CODES I WOULD BE VERY GRATEFUL IF YOU POST THEM.
    THANKS!
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings jwebbo,
    I have pasted the code that you sent me via email. I am not in the habit of assisting members outside of the pervue of the forum. It defeats the purpose of the forum which is to share information among the membership at large. It also robs you of insights into your problem supplied from other members.
    hgmjr
  3. jwebbo
    Jul 23, 2010
    Attention to SGT WOOKIE or ANYONE ELSE.
    thanks for your response in advance.
    Here is my codes. note that this code is working on my 16f877 pic.the codes only displays the values of the adresl register(0-255) although it is a 10 bit conversion. i do not know to how to combine the two registers.please help with this.
    also the adc is only responding to inputs to RAO/ANO.i have tried changing the adcon0 register's bits 5-3 to convert various channels inputs but it has not worked.
    how may i display multiple inputs on the sev seg display one after the other.
    Code ( (Unknown Language)):
    1.
    2.
    3.
    ;project to do analog to digital conversion
    ;done by jwebbo
    ;2010-07-13
    ;declearations
    porta equ 05
    portb equ 06
    trisa equ 85
    trisb equ 86
    portd equ 08
    trisd equ 88
    porte equ 09
    trise equ 89
    status equ 03
    pclath equ 0A
    disreg equ 20
    pcl equ 02
    r1 equ 26
    r2 equ 21
    r3 equ 22
    r4 equ 23
    r5 equ 24
    r6 equ 25
    r7 equ 27
    r8 equ 28
    r9 equ 29
    r10 equ 30
    r11 equ 31
    r12 equ 32
    r13 equ 33
    adresh equ 1E
    adresl equ 9E
    adcon0 equ 1F
    adcon1 equ 9F
    pir1 equ 0C
    pie1 equ 8C
    intcon equ 0B
    org 00
    clrf status
    movlw 00
    movwf pclath
    goto start
    init clrf r1
    clrf r2
    clrf r3
    clrf r4
    clrf r5
    clrf r6
    clrf r7
    clrf r8
    clrf r9
    clrf r10
    clrf r11
    clrf r12
    clrf r13
    clrf adresh ;clear a/d result high register.
    clrf adresl
    bsf status,5
    movlw b'11111111'
    movwf trisa
    movlw b'00000000'
    movwf trisb
    movlw b'00000000'
    movwf trisd
    movlw b'00000000'
    movwf trise
    bcf status,5
    movlw b'10000010'
    movwf adcon1
    movlw b'01000011'
    movwf adcon0
    retlw 00
    delay1 movlw d'24' ;this delay loop is to allow for a correct reading (wait acquisition time).The delay is 24 micro seconds.
    movwf r10
    loop1 decfsz r10,1
    goto loop1
    retlw 00
    DELAY movlw d'1'
    movwf r11
    LOOP3 movlw d'1'
    movwf r12
    LOOP2 movlw d'250'
    movwf r13
    LOOP1 NOP
    DECFSZ r13
    GOTO LOOP1
    DECFSZ r12
    GOTO LOOP2
    DECFSZ r11
    GOTO LOOP3
    RETLW 00
    sevseg addwf pcl,f
    retlw 3F
    retlw 06
    retlw 5B
    retlw 4F
    retlw 66
    retlw 6D
    retlw 7D
    retlw 07
    retlw 7F
    retlw 6F
    start call init
    clrf porte
    ;-----------Initiate a/d conversion----------------
    main bcf adcon0,2
    bsf adcon0,2 ;this instruction starts the a/d conversion progress.
    call delay1 ;waiting for the acquisition time
    ;once the conversion is completed,the go/done bit is automatically cleared and we need to check for the this.
    test btfsc adcon0,2
    goto test
    ;clrf portd,0
    clrf r1
    clrf r2
    clrf r3
    clrf r4
    clrf r5
    clrf r6
    movf adresl,w
    movwf r1
    con_1 movf r1,w
    movwf r2 ; will contain 10s and 1s
    incf r3,f
    movlw d'100'
    bcf status,0
    subwf r1,f
    btfss status,0
    goto next
    goto con_1
    next
    decf r3,f
    con_2
    movf r2,w
    movwf r4
    incf r5,f
    movlw d'10'
    bcf status,0
    subwf r2,f
    btfss status,0
    goto next_1
    goto con_2
    next_1
    decf r5,f
    goto display
    display
    movf r3,w
    call sevseg
    movwf portb
    bsf portd,1
    call DELAY
    bcf portd,1
    movf r5,w
    call sevseg
    movwf portb
    bsf portd,2
    call DELAY
    bcf portd,2
    movf r4,w
    call sevseg
    movwf portb
    bsf portd,3
    call DELAY
    bcf portd,3
    movlw d'0' ;these codes displays '0' on the leftmost digit on the sevseg display.
    call sevseg
    movwf portb
    bsf portd,0
    call DELAY
    bcf portd,0
    goto main
    end
  4. jwebbo
    Jul 23, 2010
    Hey everyone myself and others have managed to solve the problem. here is the code. ENJOY!!!
    ;done by jwebbo
    ;2010-07-13
    ;declearations
    porta equ 05
    portb equ 06
    trisa equ 85
    trisb equ 86
    portd equ 08
    trisd equ 88
    porte equ 09
    trise equ 89
    status equ 03
    pclath equ 0A
    disreg equ 20
    pcl equ 02
    r1 equ 20
    r2 equ 21
    r3 equ 22
    r4 equ 23
    r5 equ 24
    r6 equ 25
    r7 equ 26
    r8 equ 27
    r9 equ 28
    r10 equ 29
    r11 equ 30
    r12 equ 31
    r13 equ 32
    r14 equ 33
    r15 equ 34
    r16 equ 35
    r17 equ 36
    adresh equ 1E
    adresl equ 9E
    adcon0 equ 1F
    adcon1 equ 9F
    pir1 equ 0C
    pie1 equ 8C
    intcon equ 0B
    org 00
    clrf status
    movlw 00
    movwf pclath
    goto start
    init
    clrf r1
    clrf r2
    clrf r3
    clrf r4
    clrf r5
    clrf r6
    clrf r7
    clrf r8
    clrf r9
    clrf r10
    clrf r11
    clrf r12
    clrf r13
    clrf r15
    clrf r16
    clrf r17
    clrf r14
    clrf porte
    clrf porta
    clrf pir1
    movlw b'01000011'
    movwf adcon0
    bsf status,5
    movlw b'11111111'
    movwf trisa
    movlw b'00000000'
    movwf trisb
    movlw b'00000000'
    movwf trisd
    movlw b'00000000'
    movwf trise
    movlw b'10000010'
    movwf adcon1
    clrf adresl
    bcf status,5
    retlw 00
    movwf r10
    loop1 decfsz r10,f
    goto loop1
    retlw 00
    DELAY movlw d'1'
    movwf r11
    LOOP3 movlw d'1'
    movwf r12
    LOOP2 movlw d'250'
    movwf r13
    LOOP1 NOP
    DECFSZ r13
    GOTO LOOP1
    DECFSZ r12,f
    GOTO LOOP2
    DECFSZ r11
    GOTO LOOP3
    RETLW 00
    sevseg addwf pcl,f
    retlw 3F
    retlw 06
    retlw 5B
    retlw 4F
    retlw 66
    retlw 6D
    retlw 7D
    retlw 07
    retlw 7F
    retlw 6F
    start call init
    main
    bcf porta,0
    ;bsf pie1,6 ;clearing ADIE bit
    ;bsf status,5
    ;bsf pir1,6 ;clearing ADIF bit
    ;bcf status,5
    ;bsf intcon,6 ;setting PEIE bit
    ;bsf intcon,7 ;setting GIE bit wwwwwwwwwwwwwwwwwwwwwwwww
    test btfsc adcon0,2
    goto test
    clrf r1
    clrf r2
    clrf r3
    clrf r4
    clrf r5
    clrf r6
    clrf r7
    clrf r8
    bsf status,5
    movf adresl,w
    bcf status,5
    movwf r1 ; r1 contains the lower bytes
    movf adresh,w
    movwf r2 ; r2 contains high bytes
    incf r2 ; to correct for error (adds 256 to result)
    test_1 movf r1,w
    movwf r3 ; holds the remainder of the subtraction
    movlw d'100'
    subwf r1,f
    incf r4 ; contains hundreds
    btfsc status,0 ;
    goto test_1
    decfsz r2
    goto test_1
    decf r4
    bcf status,0
    test_2 movf r4,w
    movwf r5 ; contains hundreds
    movlw d'10'
    subwf r4,f
    incf r6
    btfss status,0
    goto forward
    goto test_2
    forward decf r6 ; contains thousands
    bcf status,0
    test_3 movf r3,w
    movwf r7 ; contains ones
    movlw d'10'
    subwf r3,f
    incf r8
    btfss status,0
    goto forward_2
    goto test_3
    forward_2 decf r8 ; contains tens
    bcf status,0
    ;goto display
    display
    movf r6,w
    call sevseg
    movwf portb
    bsf portd,0
    call DELAY
    bcf portd,0
    movf r5,w
    call sevseg
    movwf portb
    bsf portd,1
    call DELAY
    bcf portd,1
    movf r8,w
    call sevseg
    movwf portb
    bsf portd,2
    call DELAY
    bcf portd,2
    movf r7,w
    call sevseg
    movwf portb
    bsf portd,3
    call DELAY
    bcf portd,3
    goto main
    end
