A Converter without a transformer
Discussion in 'The Projects Forum' started by Mahmoudtak, Feb 28, 2014.
Thread Status:
Not open for further replies.
  1. Mahmoudtak
    Feb 28, 2014
    Is it possible to have a 110 v AC to 12 v DC converter circuit without using a transformer?
  2. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi,
    It is possible to do that conversion, but I would only recommend using that method providing that the PSU is sealed in order to prevent a possible electric shock as there is NO isolation from the 110V supply.
    How is the PSU going to be used.?
    E.
  3. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    NEVER EVER try to make a power supply without a transformer!! Its impossible to get isolation from the mains.
  4. tshuck
    Oct 18, 2012
    3,531
    675
    The danger involved is why it is against the terms of service to discuss their implementation.
    But, yes, it is possible.
  5. Mahmoudtak
    Feb 28, 2014
    I have recently opened the internal circuit of an LED bulb which works with 110 v AC to drive 4 LEDs which they need 12 v DC. This circuit includes only 2 resistors, a capacitor, and an Ic probably a Diode bridge. I' m wondering how it may work without a transformer!!?
  6. mcgyvr
    Oct 15, 2009
    4,784
    973
    Just go to google and search "transformerless power supply"..
    This post is going to be locked soon because the owners of this site have decided that it is against the rules to discuss these types of power supplies on this forum because it can be very dangerous for inexperienced users..
  7. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi Mahmoudtak,
    If you have to ask how a transformer-less, non mains isolated converter works, my advice would be not to attempt to copy/build or repair this type of unit.
    The low cost of a transformer isolated 'wall wart' or equivalent type is well worth the investment.
    E
  8. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    And never throw away the transformer when you take apart say old amplifiers and other stuff.
    Over the years i've built up a large inventory of various transformers ranging from 15VA up to 1.5kVA.
  9. MrChips
    Oct 2, 2009
    12,623
    3,451
    Please note that discussion of transfomer-less power supplies is prohibited on All About Circuits.
    This thread is against AAC forum rules, Chapter 6, as seen here:
    This can be found in our Terms of Service (ToS).
    There are other sites that may be able to answer your questions.
Thread Status:
