This is for a project that utilizes a v-twin 25hp motor, but I feel the nature of the question is more electronics oriented, thus I have posted here.
We have constructed a device that drives itself with a small 25hp gas engine. The transmission is hydraulically actuated and we use a series of remotely-controlled valves to spin one side of the drivetrain (left front and back, or right front and back,) so effectively a skid loader in a sense. Anyhow, the remote control for this unit has e-stop functionality, which is provided in the form of a 12VDC normally-closed line available off the hydraulic transceiver's harness. The hydraulic transceiver is powered by the 12V battery, which is the primary cold cranking source for the engine. Simply put, everything is sourced from the battery.
I want to integrate this function to the engine to shut down the fuel pump. On the engine it's simple: ground a wire and it does just that. My original thought was to run the 12V (NC) from the hydraulic harness into the control line/coil of a normally-closed relay so that if the e-stop is engaged, it open circuits the e-stop line and the relay is closed, grounding the ignition shutoff circuit and disabling the fuel pump. This circuit should work fine, but I need something that won't be disrupted when the engine cranks. While cranking, the 12V is temporarily unavailable, thus the primary relay channel will close and ground the engine shutoff circuit, presumably not allowing it to start.
Is a timer or a capacitor the best fundamental approach to this issue? My thought is to either create a timed latch or create a temporary capacitance, though admittedly the capacitance might not be the safest approach if an emergency stop situation is desired.
Thoughts? References to example circuits?
Thank you,
Mel
Thank you,
Mel
