hi guys
can anyone explain how does this circuit solve the solution of load having high current requirements
the document says that in absence of transistor , the zener diode regulates a constant voltage across itself by allowing maximum current through the series resistor
and when we have a load with greater current requirements, we use this configuration of a transistor to solve that problem
what i dont get is how in this circuit transistor solves the problem. please answer according to the flow of current. dont give mathematical equations for solution.
i want to know the flow of current that occurs in it and how it increases with placement of a transistor from the one in its absence through the resistor
