I have a problem at work where the polarity on capacitors is mismarked. I'd like to find a way to test if the polarity is wrong non-destructively. This would be out of circuit.
Check out this PDF document that Sencor put out regarding testing non-polarized electrolytics using their Z-meter: www.sencore.com/custsup/pdf/TT139.pdf
The equivalent representation of polarized vs nonpolarized electrolytics is illuminating.
If you don't have an NE566/SE566 handy (they're getting scarce, Electronic Goldmine has run out), you might try using a single CMOS 4093 NAND gate as an oscillator. You could use the remaining three gates to drive a small speaker or the like.
fill the cap with a small voltage, say 1 volt or so, test the voltage drop in 10 seconds or so. test it in both polarity. the least voltage drop is the right polarity.
