Breaker! Beaker!
Should an input signal voltage to common emitter amplifier should reach saturation (that is out volt/current)when the signal input voltage is amplified or increased to an ampltude that is half the D.C. bias voltage and current?Is this true?
.If a.c. is riding on D.C.the signal input must produce a result that is half of the of the Vce, VRL, IRload? Is this correct understanding ? That is, gain in voltage or current must be only half of the quiescent point of operation since a.c. is riding on D.C., realizing that a.c. added to D.C. should produce Quiescent Bias parameters. Which seems reasonable to think that a specify gain current or voltage that uses only half of the D.C. Quiescent operation and the other half is the signal voltage or current.
