a BJT Op
Discussion in 'Homework Help' started by NCH, Feb 28, 2013.
  1. NCH
    Feb 28, 2013
    12
    Hello there! This is my first post here so i hope i get this about right.
    My english isn't really perfect but ill try to keep it at a normal level:rolleyes:
    I've gotten an asignment to simulate a OP amp with BJT and resistors!
    I've already figured out this isn't as easy as it seems thru several attempts at it. Really the biggest issue i have is that i don't really know the real analysis of the circuit at a basic level. I'm looking for someone to give a explanation of the different parts that i've figured out the OP consists of.
    Probably the most important part is the current-mirror and the input stage of the OP.
    I can't really figure out how to choose my hFe for each of the pnp/npn transistors. Any help is greatly appreciated! A have a basic level of electronics so you know at what level i could use somekind of help.
    My electronic teacher said that some pairs of transistors shouldn't have the same hFe but that didn't really help me much with this i feel..
    Where should i begin with this?:confused:
    Here's an example of the circuit!
    http://imageshack.us/photo/my-images/94/skrmavbild20130220kl150.png/
  2. ScottWang
    Aug 23, 2012
    4,930
    777
    Where did you get the idea of that circuit?
    Where is the Totem Pole of output, as uA741, LM358, LM324, Op07, etc...
    No kidding, you want to build a new type of output?
    You can check the output of those Op Amp.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    I'm guessing the OP's task is not to re-invent a commercial op-amp. Rather the task seems to be to gain a simple understanding of the essential parts of an op-amp. In principle the op-amp is a differential input signal amplifying device having substantial gain-bandwidth and a single ended output. The attached schematic from NCH essentially fits that concept - using discrete components. The inclusion of a totem pole output isn't an absolute necessity.
    The OP hasn't really made it clear whether the requirement is to produce a physical working circuit or a simulator based equivalent.
    From NCH's perspective I'm surprised that this task has been given to someone with only "a basic level of electronics". In any event, there is more than sufficient information on BJT based differential amplifiers [input stage] and current mirrors on the web. Google is probably your friend in this case.
    For example, there is a discussion of current mirrors here ...
    http://www.allaboutcircuits.com/vol_3/chpt_4/14.html
  4. NCH
    Feb 28, 2013
    12
    thank your for quick answers!
    well the task itself is to be adle to use the circuit for simulation but if this circuit would even be enough i'm not sure of, its only an example given to us be our teacher. The simulation does require us to use it to figure out different things about the OP. Such as bandwidth,risetime,gain,offset,cmrr railtorail etc..
    Would you say this circuit is enough to simulate this?
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes it will be fine - but you will have to adjust values according to transistor characteristics and this would require both a careful DC & AC analysis to design and then set up [with some tweaking] the correct DC operating conditions and expected gain performance.
    In other words you need a design specification as a starting point.
  6. NCH
    Feb 28, 2013
    12
    if anyone wants to give me some advice im still reading the thread! =)
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    What is "enough"? You haven't provided any performance specifications to work against.
    Go ahead and use this circuit and perform the sims to get the numbers for each of the parameters you mentioned. Then figure out (by analysis and design, not by random parameter changing) what changes you need to make in order to move in the direction toward acceptable performance (as determined by those pesky specifications).
