thatoneguy
- Joined Feb 19, 2009
- 6,359
All what you said, and then there's also the peukert effect holding you back. I don't exactly understand the peukert effect, but it causes you to lose AH at higher than rated discharge rates. A thumb rule I have encountered before is that if you double the discharge rate, to don't half the time, you quarter it. for example if the datasheet specifies 10AH @ 500mA - so then if you put a put a 500mA load on it, it should last 20hr. logic would then dictate that @ 1A discharge you should get 10hrs, but in reality you would get 5hrs max. As I said this is just a thumb rule I heard, and I'm not sure how accurate it is; I know there is a more scientific way to calculate the peukert effect, yo could look it up if interested.
The reason for this is the "best" areas of contact between anode and cathode get burned into inactive material at a very high load, though they will produce it for a while. Think of them as a range of fuses for various currents, the more you blow, the fewer good fuses you have left to supply current, and internal resistance goes up.
The datasheet used to show internal resistance vs time @ set current draws, but they've stopped including those in datasheets for non-rechargeable batteries, I'll try to find one from the olden days. They basically looked like a Diode's Vf curve at high current, crossing 1Ω quickly with a 1A load on AA cells, while being a pretty much linear line at at 25mA draw.
Analogy would be the "bubbles" in NiMH/NiCd batteries that buildup and limit discharge rates/internal resistance.
There's not really a formula for it in general, it needs to be figured out per battery, and the battery is ruined figuring it out. Though the measurements you get give good rules of thumb for other batteries of that type from the same manufacturer.
The info is around and out there if you search for it, usually in the "battery blowouts" where a Cadex charger/discharger is used to plot voltage, internal resistance, etc at different crrent draws in order to rank Energizerabove Duracell Extra, but below Energizer lithium. These are the consumer report type tests where they drain them at "typical usage" for everything from radios to flashlights to cameras. When the numbers and charts are included, they are very informative.
