A basic question about MOSFET...
Discussion in 'General Electronics Chat' started by Vorador, Jun 5, 2013.
  1. Vorador
    Oct 5, 2012
    87
    When a positive potential is applied at the gate, electrons are attracted toward it and form a channel between the drain and source. I wanted to know whether these electrons that form the channel are "free" electrons or rather negative ions? I think they must be ions because prior to the formation of the channel, there must've been acceptor atoms in that region. So when the bias is applied and electrons fall into those atoms, they should become negative ions.
    If my guess is correct, are these ions mobile? i.e can they participate in conduction?
    Thank you! :)
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    I don't know nothing about semiconductors physics. But I suspect it must be a free electrons.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Ions are static, making up the crystal lattice structure and cannot move.
  4. crutschow
    Mar 14, 2008
    13,509
    3,385
    The only moving charge in semiconductors is electrons. Even when we talk about positive "holes" in P-material it's still really the electrons that do the moving.
    absf and screen1988 like this.
  5. circuitfella11
    Member
    May 10, 2013
    56
    5
    negative ions/ electrons.. they're the only ones that does move.. they regarded p-materials as holes, they don't move, but it is where electrons pair up to stabilize it.. the material is so little in the gate..the bias applied turns the mosfet on or off..so the bias applied makes the reaction on the material to let pass or not let pass from source to drain.
  6. Vorador
    Oct 5, 2012
    87
    That answers one of my questions, crutschow. I also wanted to know what the channel is "made" of. Neutral atoms with a free electrons, or atoms with an excess of electrons (negative ions)? And why doesn't the current start flowing until the "channel" has formed? I mean, in a semiconductor P-N diode, electrons move from the N region into the P region. So what stops electrons from going from the N region, through the P region substrate and to the other N-region in a MOSFET? Why is an "N channel" that connects the two separated N-regions necessary to make the electrons flow in MOSFETs?
  7. crutschow
    Mar 14, 2008
    13,509
    3,385
    The channel is made of the material in the substrate which is opposite the MOSFETs channel type. This explains it better than I could.
  8. Vorador
    Oct 5, 2012
    87
    Thank you.
