A band pass filter which doesn't alter my signal
Discussion in 'The Projects Forum' started by nyasha, Nov 2, 2011.
  1. nyasha
    Thread Starter Active Member
    Mar 23, 2009
    90
    Okay, so l want to design a band pass filter that doesn't attenuate my signal. Is that possible. I want it to allow frequencies between 1khz and 3khz. I have tried to make one, but it ends up with my signal getting attenuation. Any hints on how l can achieve this ?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Do you mean an active filter design?
  3. justtrying
    Mar 9, 2011
    329
    396
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you're going to make a passive filter, you'll have some loss. The better you tune the filter, the less loss you'll have.
    Here's a pretty decent one I threw together; it's a modification of a Cauer.
    See the attached for a plot of the transmission (S21) and reflection (S11).
    At 1kHz, the signal is about -0.443dB, at the center, around -0.223db, and @3kHz, -0.288dB
    justtrying and nyasha like this.
  5. joeyd999
    Jun 6, 2011
    2,757
    2,931
    nyasha likes this.
  6. nyasha
    Mar 23, 2009
    90
    I think the tank filter which shorts out signals within the frequencies l do not like is what l will try to design given the parts l have which include only one 10mH inductor. I will post my multism circuit for you guys to critique. Thanks very much for the hints.
  7. crutschow
    Mar 14, 2008
    13,498
    3,374
    An active filter is a good fit for this application and requires only resistors and capacitors. You can easily design one using TI's free software.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You missed the part about the opamp. ;)
  9. justtrying
    Mar 9, 2011
    329
    396
    well then, active is the way to go, does not sound like you would need a fourth order one (although it is impressive) :)
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You could always put an adjustable amplifier in front of or after your filter. This is called buffering and prevents one filter from loading a previous or subsequent stage. Most engineers, realizing the benefits of buffering, do it without giving the insertion loss a second thought.
  11. crutschow
    Mar 14, 2008
    13,498
    3,374
    True enough. I should have said the only passive components required are resistors and capacitors. Of course it's hard to have an "active" filter circuit without some sort of amplifier.:rolleyes:
