Here is a PCB layout. I made it single-sided and somewhat spacious for those who want to etch their own PCB. The input will accommodate a two-screw terminal block (Onshore Technology part# OSTTC022162) or a coaxial power jack. The output is laid out for a two-screw terminal block. Of course, you can solder wire leads directly and forego the connectors altogether. The pot is a top adjust trimmer (Bourns part# 3362P-1-502LF). The mounting holes are .125" for 4-40 screws.
Let me know if you see any errors or have any questions.
