Hello Everyone!
I am new to this site and have done a lot of reading so far. I am wanting to make a grow light as others have done. I struggle with trying to understand all the items I will need and what lay out i should use. I am hoping i can gather some support from the experts in order to make this project a success. I want to do the following:
I have the pattern down (attached image) and i know what LED's i want. Can the experts help me with a diagram, drivers, powersupply, etc? I plan on odering a heatsink with fins that will be about 24 inches long and 8-10 inches wide.
I would like a dimmer for each set of colors and would like to wire two fans in the series as well. Any help you can provide will be greatly apprectiated.
LED's
http://www.ebay.com.au/itm/10PCS-3W-Royal-Blue-High-Power-LED-Emitter-700mA-450-455NM-with-20mm-Star-Base-/320867358141?pt=LH_DefaultDomain_0&hash=item4ab52f55bd
36 3W Blue with 20mm base
DC Forward Voltage (VF) DC3.4 ~ 3.8V
DC Forward Current (IF) 700mA
Wavelength 660nm
http://www.ebay.com.au/itm/10PCS-3W-Red-High-Power-660NM-Plant-Grow-LED-Emitter-Light-with-20mm-Star-Base-/320867389761?pt=LH_DefaultDomain_0&hash=item4ab52fd141
60 3W Red with 20mm base
DC Forward Voltage (VF) DC2.2 ~ 2.6V
DC Forward Current (IF) 750mA
Wavelength 660nm
LED's
Wavelength 660nm
Wavelength 660nm
