90v dc motor controler
Discussion in 'The Projects Forum' started by anectine, Dec 28, 2012.
  1. anectine
    Dec 28, 2012
    I am new here and have a very limited (but growing) knowledge of electronic design. I Have aquired a 90v dc treadmill motor I want to use on a lathe. The mcb that came on the treadmill looks to be all solid state and I am not sure how to use it to control the motor.
    I am looking for some advice on either using this board or how to build a suitable alternative.
    The motor is 90v dc, 2.5 hp, 21 amp, and a 3100 rpm rating
    Here is a link to the service manual if that helps
    http://www.resembly.net/files/Johns...ice Manuals/2006Treadmillserviceguide 1.5.pdf
    on page 22 of the document is the drive wiring diagram
    Any help is appreciated
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    If the board is OK, maybe u can try to use it.
    May be it's easier than building a PWM driver.
    The board will handle torque far better than a DIY circuit I believe.
  3. anectine
    Dec 28, 2012
    The treadmill was a $25 cl find that works great. the running board under the belt was broken and not safe anymore. I was considering placing a pot across the EL VCC +2.5v, EL Pot, and Ground lines to see it that would power the motor.
    Any suggestions?
  4. R!f@@
    Apr 2, 2009
    8,785
    771
    to make tht kinda suggestion I need to see the PCB close range. Since without a schema it's hard to say.
    I bet the control signal is digital rather than analog.
    But still it can be done if the motor driver PCB is not toast.
