90 led's circuits
Discussion in 'Homework Help' started by myosff, Aug 18, 2013.
  1. myosff
    Aug 18, 2013
    6
    dear all
    i need full diagram circuits for 90 led's sheet led's 5 mm blue and white and power supply 12 v
    many thanks
  2. LDC3
    Apr 27, 2013
    920
    160
    JoeJester and Metalmann like this.
  3. myosff
    Aug 18, 2013
    6
    no things please advice
    any help please
  4. LDC3
    Apr 27, 2013
    920
    160
    How can we help if we do not know anything about what you want. It's like saying, build me a car!
  5. myosff
    Aug 18, 2013
    6
    need help to define all part for circuits
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    You're not making any sense. I am guessing you are not a native English speaker. In that case, I suggest you try translate.google.com. It might help you to better explain what you want, and help us to better understand you.
    Matt
  7. absf
    Dec 29, 2010
    1,493
    374
    You have to tell us more about the LED. How many are blue and how many are white. How much current and voltage is required for each color of your LED......etc
    Allen
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    And let's not forget that this is the HOMEWORK Help forum. You need to show what efforts YOU have made to at least attempt a solution for YOUR homework problem.
    DerStrom8 likes this.
  9. myosff
    Aug 18, 2013
    6
    all led's are 3.6 volt 75 mA and power supply 12 volt
  10. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    You didn't answer our questions.
  11. WBahn
    Mar 31, 2012
    18,085
    4,917
    Still waiting to see this "attempt" thing.
  12. myosff
    Aug 18, 2013
    6
    now i don't need any help
  13. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
  14. myosff
    Aug 18, 2013
    6
    many thanks max
  15. WBahn
    Mar 31, 2012
    18,085
    4,917
    So, either you figured it out on your own once you decided to make the attemp -- which is a great thing; or you concluded that we weren't going to just do your work for you and gave up -- which is a great thing.
  16. ScottWang
    Aug 23, 2012
    4,925
    777
    If you want to light up the 90 LEDs, then you should doing as this:
    12V/3.6V=3.333, 90V/3=30 strings, the power only has 12V, so you only can using 3 LEDs in a string, and then you have to calculate the limited resistor for LED current limitation.
  17. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Don't now what r u doing are u making light system??
    anyway just make 4 or 3 led series with series resistance of 100/220ohm 1/4watt as per requirement of intensity.
    and then connect all these series in parallel to 12v source...
  18. WBahn
    Mar 31, 2012
    18,085
    4,917
    How do you figure that the OP will be able to power 3 LEDs in series if they are using 12 V and each LED has a forward drop of 3.6 V?
    At the requested intensity of 75 mA, a 100 Ω resistor will drop 7.5 V and dissipate well over 500 mW while a 220 Ω resistor will drop 16.5V and dissipate nearly 1.25W. So just where did you come up with the recommendation of using "100/220ohm 1/4watt" resistors?
    With three LEDs in a string, the voltage that needs to be dropped across the current limiting resistor would be
    Vdrop = 12 V - 3 x 3.6 V = 1.2 V
    To do this at a current of 75 mA would require a 16 Ω resistor and would dissipate about 90 mW. This may work just fine, but small variations in the forward LED voltage or the supply voltage could move the actual current around by perhaps 50%. If that's acceptable, then this is probably the way to go.
    But if the OP needs a more consistent and uniform current, it would probably be better to go to two LEDs in a string, meaning that the resistor would have to drop
    Vdrop = 12 V - 2 x 4.6 V = 4.8 V
    which would require a 64 Ω resistor (use a 62 Ω if you need it close or a 56 Ω or a 68 Ω if you can be a little loose) capable of dissipating 360 mW. So two 1/4 W 33 Ω resistors in series might be a way to go. With this, it is probably unlikely that the current will vary more than about 10% from the nominal value.
  19. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, if there are 8 Led white in series with 220ohm at 1/2 or 1/4 watt resistor(in paraallel there are more than 1000's led) driving from 26V source is not giving good brightness, increasing voltage to 46V will damage the led?
  20. WBahn
    Mar 31, 2012
    18,085
    4,917
    What, on Earth, are you rambling about? Who said anything about 8 LEDs in series? Or thousands of LEDs? Or about 26 V sources? Or about 46 V sources?
    Are you sure you are in the right thread on the right plane of existence?
