Plug in the values and it will spit out the part you need. I came up with the LM25575 but I can't find the specs on the power output of a 9v battery so don't know how much power it can produce.
If you make a voltage converter circuit that is 85% efficient and need 400mA at 12V then then 9V battery must supply 640mA.
A 9V alkaline battery's voltage drops quickly with such a heavy load. I have graphs from energizer.com and the highest current calculated is "only" 400mA.
