9-volt wiring through cardboard house to light up
Discussion in 'The Projects Forum' started by shadowed.angel, May 11, 2008.
Who has had experience w/ using a 9-volt battery n' wires to light something up?
Poll closed May 15, 2008.
  1. using wires and such
    0 vote(s)
    0.0%
  2. and etc
    0 vote(s)
    0.0%
  1. shadowed.angel
    May 8, 2008
    5
    If at all possible, can someone please explain how i would get this all work w/out a plug. But also explain to me if someone has ever done this. It would be a great deal of help, please and thank you.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I think you'll have to provide more information before getting a coherent answer. LED's come to mind, but I have no clue what your trying to accomplish.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Strongly agree. The question verges on incomprehensible. How could we possibly know if something we do not fully understand has been done before? What are we supposed to understand by "w/out a plug"?
    Are you trying to place lighting (incandescent or LED) into a model house? If so, do all the illuminators come on at once, or do they need to be individually controlled?
  4. shadowed.angel
    May 8, 2008
    5
    The question in which you have replied with is the one that I was trying to ask. Having to deal with trying to illuminate up a model house with lights of any sort. In which this house is made of cardboard, being wired to a 9 volt battery. In which, my question is: has anyone try to do this sort of thing?
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    You ask a bunch of techie nerds if we've build doll houses? :) Nope, I never have. Just from an electronics point of view, use very lightweight insulated wire and solder it to the LEDs. Do you know how to solder? How much do you know about LED's and resistors?
  6. shadowed.angel
    May 8, 2008
    5
    I'm not talking about a doll house. This is a science project. And I have to admit; I know nothing about solder. If you could tell me what it is, it would be greatly appreciated. Thank you. And I'm not much of a science person, thats why I started this. Hoping to find out if anyone knows how to do this and etc.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    We know that a little 9V battery doesn't have enough power to light many lights for more than a few seconds.
    We know how to design a simple circuit that has a big battery or a power supply and many lights with switches.
    We know how to solder connections.
  8. shadowed.angel
    May 8, 2008
    5
    I'm asking what yall mean by soldering? And I know that the 9V battery will only a little bit of power.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Basically, wiring up LED's (Light Emitting Diodes) is wiring up LED's, doesn't matter if it's a house or a printed wiring board.
    A basic LED circuit consists of a current source (like a battery) a current limiter (such as a resistor) and the LED itself, with interconnecting conductors (wires, PWB traces, etc.)
    You will probably want to use white LEDs. A 3mm or 5mm white LED usually has a Vf (forward voltage) somewhere in the range of 3.4v-3.9v with 20mA of current through it.
    So then you need to calculate the value of Rlimit, the current limiting resistor. This depends upon three things:
    1) The desired current through the LED
    2) The Vf of the LED at that current
    3) The supply voltage
    Rlimit = (Vsupply - Vf(LED))/Desired Current
    Rlimit = (9V - 3.6V) / 20mA (0.02A)
    Rlimit = 5.4/0.02
    Rlimit = 270 Ohms.
    When the battery (alkaline) is fresh, you'll get 20mA of current through the resistor and LED.
    A 9v alkaline battery is usually rated for somewhere around 500mAh. Many don't start out at 9v; more like 8.4v. But anyway, 500mAh means it can supply a current of 500mA for one hour, but more like 50mA for 10 hours. In your case, since you have a 20mA load, it will power your single LED for 500/20=25 hours.
    If you add more lights, it will shorten your battery life somewhat porportionately.
    But, batteries are much better at powering light loads than they are at powering heavy loads. If you have a lot of load on a battery, it starts heating up due to it's internal resistance. This heat is wasted power. If you had, say, 5 LEDs drawing a total of 100mA, your battery would likely last much less than 5 hours.
  10. shadowed.angel
    May 8, 2008
    5
    :)Thank you for all your help.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    If you have specific questions, like how to hook them up, you'll find a lot of help around here, but we can't help you if you stay vague on details. This is a science project, and you want to do what?
  12. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    And why is the poll significant?
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    Betcha they were trying features out. Gotta learn them somehow.
  14. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I put "wheat grain" bulbs in my HO scale buildings when I was in Junior High. Does that count?
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    Ikea sells a string of tiny LEDs. They are powered with two AA alkaline battery cells.
  16. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    To get closer to the topic, I would never use a 9 volt battery if I wanted to have anything lit for more than 10 minutes. LED's or bulbs.
