9 Volt 250mAh Ni-MH rechargable battery charger
Discussion in 'The Projects Forum' started by RodneyB, Sep 21, 2014.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    647
    14
    I am trying to make a charger for my 9 volt rechargeable Battery.
    I was wondering if the attached circuit is suitable.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    No, there is no current limitation.
    Without any current limitation you could overheat the battery.
    Bertus
    RodneyB likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Bernard and RodneyB like this.
  4. RodneyB
    Apr 28, 2012
    647
    14
    Thank you for all the advice and assistance
    Best wishes
    Rodney
  5. jjw
    Member
    Dec 24, 2013
    174
    31
    9V battery is usually made of 7 cells and it's voltage after full charge can be ~ 10.5V.
    12V supply voltage is probably too low because LM317 needs even with small currents at least 1.5V differential between in and out terminals + 1.25V over the current limiting resistor.
    15V supply should be enough.
    It is recommend to charge the battery 12h at 10% current, because the charging efficiency is not 100%.
    RodneyB likes this.
  6. upopads2
    Member
    Sep 20, 2014
    52
    This is a great circuit thanks for sharing.
    RodneyB likes this.
