9-0 down counter using JK Flipflop
Discussion in 'Digital Circuit Design' started by Mondemundi, Sep 20, 2016.
  1. Mondemundi
    Sep 20, 2016
    Hi ! I am currently making a 9-0 counter using a jk flipflop and a 7 segment.
    It starts to countdown but the problem is it starts at 15 not in 9 how can i make it start at 9 and reset again. Thank you very much !
  2. AlbertHall
    Jun 4, 2014
    2,277
    449
    connect the appropriate set/reset pins of the flip-flops to the active state (might be high or low depending on which JK you are using) to set the '1001' state.
    Mondemundi likes this.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    652
    Welcome to AAC!
    Is the counter synchronous or asynchronous?
    Is this homework?
    Post a schematic. Anytime you ask a circuit question and don't post a schematic, expect to be asked to do so.
  4. Mondemundi
    Sep 20, 2016
  5. Mondemundi
    Sep 20, 2016
    Yes sir this is an Asynchronous Counter..
    I am currently working on this and getting really frustrated.. i have attached the schematic i made.. the other preset and clear are on the HIGH state
    pls check if its right Thank you very much
  6. AlbertHall
    Jun 4, 2014
    2,277
    449
    so the count goes (in the order drawn):
    1001 9
    0001 8
    1110 7 <= NAND gate inputs both 1
    1000 1
    I think you may need a wider NAND.
  7. Mondemundi
    Sep 20, 2016
    Thanks sir .. Ill try it nooww
  8. dl324
    Mar 30, 2015
    3,379
    652
    Is this homework?
    Why are you decoding 10? This is a count down counter that starts at 15. You need to get the counter out of the illegal states when the count is 15.
