9-0 down counter using d flip flop
Discussion in 'Homework Help' started by annbarbie01, Oct 1, 2013.
  1. annbarbie01
    Oct 1, 2013
    12
    pls help..
    i need to build a 9 to o down counter using d flip flop. i'm just a newbie, so i have no idea where to start...
  2. Max Kreeger
    Member
    Oct 1, 2013
    71
    An actual circuit? Or just design the logic gates? How many bits? Are you going to implement the design on a board? - Going to need a little bit more info chief haha.
  3. MrChips
    Oct 2, 2009
    12,622
    3,451
    This is a common exercise in an introductory course on digital logic sequential design.
    There are three steps:
    1. Draw the truth table of current state and next state.
    2. Draw Karnaugh maps for each flip-flop.
    3. Implement combinational logic for specific type of flip-flop used.
    You can pick up the steps here:
    http://forum.allaboutcircuits.com/showthread.php?t=58572
    anhnha likes this.
  4. annbarbie01
    Oct 1, 2013
    12
    oh i'm sorry. yeah, i need to put it on PCB. it's 9 to zero so four bits, XD
  5. annbarbie01
    Oct 1, 2013
    12
    is my truth table correct?
    DCBA DCBA(next state)
    1111 xxxx
    1110
    1101
    1100
    1011
    1010 xxxx
    1001 1000
    1000 0111
    0111 ...
    0110
    0101
    0100
    0011
    0010
    0001 ...
    0000 1001
  6. MrChips
    Oct 2, 2009
    12,622
    3,451
    No.
    In the left column, list all possible states, 0000 - 1111, in order.
    In the right column, list the state that follows from the current state (in left column).
    If the current state does not exist, put XXXX in the right side column.
    0000
    0001
    0010
    0011
    0100
    0101
    0110
    0111
    1000
    1001
    1010
    1011
    1100
    1101
    1110
    1111
    anhnha likes this.
  7. tshuck
    Oct 18, 2012
    3,531
    675
    anhnha likes this.
  8. annbarbie01
    Oct 1, 2013
    12
    I'm sorry, I thought it should be like that since i'm counting down. XD
    Sir, I've done it already and also the kmap. this is what i've got.
    for A: D'
    for B: CD' + A'C'D
    for C: BC' + BD' + B'CD
    for D: AD' + BCD
    is it correct? how am i going to implement it on the d flip flop? thank you so much.
  9. annbarbie01
    Oct 1, 2013
    12
    argh, someone told me i should make the truth table from nine. but i already did the 0-9. i'm in a bind now.
  10. MrChips
    Oct 2, 2009
    12,622
    3,451
    It does not matter what order you create the truth table. The order can be totally random, so long as you include all of the states, used or not used.
    It is simply straight forward to go from 0 to 15 so that you do not miss a state.
    My results of the Karnaugh maps do not match your expressions you have shown.
    anhnha likes this.
  11. annbarbie01
    Oct 1, 2013
    12
    then here's my truth table..
    0000 0001
    0001 0010
    0010 0011
    0011 0100
    0100 0101
    0101 0110
    0110 0111
    0111 1000
    1000 1001
    1001 0000
    1010 xxxx
    1011 xxxx
    1100 xxxx
    1101 xxxx
    1110 xxxx
    1111 xxxx
    i did kmap again and still arrived at the same results.
  12. MrChips
    Oct 2, 2009
    12,622
    3,451
    You have shown a count up sequence 0-9.
    I thought you needed count down 9-0.
  13. annbarbie01
    Oct 1, 2013
    12
    ahh.. i get it. sorry.
    A: D
    B: C'D' + A'D + B'CD
    C: B'D' + A'D + B'C'D
    D: A'D' + ABCD
    is it correct? thanks again.
  14. WBahn
    Mar 31, 2012
    18,065
    4,905
    In general, we need to see HOW you arrived at a result and not just the result you arrived at. Our goal is to help you understand how to solve a problem, not just confirm or deny that your result is correct.
    One of the nice things about most engineering disciplines is that you can verify the validity of a result from the result itself. You don't need to (and need to learn not to) rely on others to tell you if you are correct or not.
    So take your solution and then analyze the behavior of the circuit that results. If it matches the behavior that you want, then it is correct. Otherwise, it ain't.
    QD QC QB QA DD DC DB DA QD' QC' QB' QA' Description
    0 0 0 0 1 1 1 0 1 1 1 0 0 => 12
    Already we can see that the equations you came up with will NOT result in the behavior you want.
    So how about showing the K-map for one of the stages, say the first one or the last one, so that we can see how you arrived at the equation you did?
    anhnha likes this.
  15. annbarbie01
    Oct 1, 2013
    12
    i didn't get the table, sorry.
  16. WBahn
    Mar 31, 2012
    18,065
    4,905
    If you are referring to the table in my last post, then it is nothing more than the start of a state transistion table.
    I chose (0000) as the starting state for the four Q outputs.
    I then used your proposed equations to find the values of the four D inputs.
    I then applied the inputs to find the next set of four Q outputs.
    I then noted the numeric values associated with this transistion.
    Since you want 0->9 and not 0->12, there is a problem.
