Hi
I need help with run capacitor. I have a zanussi tumble dryer 250volt 2800watt.. Capacitor was dead, so ordered a new capacitor(wrong one) direct from Zanussi, which is 8uF 425/475 volt rating with -2% and +8% tolerance. The actual capacitor in the tumble dryer is 9uF with similar rating and tolerance. I replaced it anyway just to test if it runs.
It does work but I am worried that can it do some damage in the long run as it is 8uF instead of 9uF.
So if someone can advise me that should I keep using it or should I replace it with the 9Uf.
Thanks.
Thanks.
