1. Jaguarjoe
    Thread Starter Active Member
    Apr 7, 2010
    770
    90
    I'm still a body end dot guy so this one is new to me:
    What is the value of an 8E2 resistor? It can't be 8^2, and if it was 8.2Ω, it should be 8R2. Or, as usual, am I missing something obvious again?
    I'm like that Farside kid trying to enter the Engineering Bldg. He was pushing on the door with all his might while the sign on the door said pull.
    It is an isolation resistor at the output of a 5532 opamp driving a 32Ω headphone from a 4.5v supply.
    Is this explained somewhere?
    Thank you,
    Joe
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    I never heard of it either, but when I google 8e2 resistor, I get a lot of hits for 8.2 Ω resistors.
  3. #12
    Nov 30, 2010
    16,704
    7,353
    Maybe it's like a personalized license plate, "eight-e-two":D
    But seriously, you have it in your hand, don't you? Measure it with an ohm meter.
    My guess is 8.2 ohms because that would protect the amplifier and not waste most of the power for the headphones like an 82 or an 800 ohm resistor.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The minimum allowed supply voltage for an NE5532 is 6V but yours is 4.5V that might drop to 3V. Not good.
    The datasheet for an NE5532 opamp shows the minimum load is 600 ohms and the minimum output into 600 ohms is 12V. Then the maximum current is 12/600= 20mA.
    Your load is 32 + 8.2= 40.2 ohms. Then a peak of 20mA produces a peak output of 40.2 x 0.02= 0.8V. Then the maximum output is 0.57V RMS. The maximum power in each earphone is 6.4mW RMS. Not very loud.
  5. Jaguarjoe
    Apr 7, 2010
    770
    90
    By no means is this "my amplifier". I've been Googling to see how other people make headphone amps. Lots of options, some much better and some much worse than others, obviously the 5532 solution as is done by Vellman in their $10 kit is not acceptable.
    I've been gyrating around 1/2 of a TL074 in parallel. or 1/4 of a TLC074. The TLCx looks like a nice part. If there's something better than it, please let me know.
    #12-
    I don't have that 8E2 in my hand, its only on paper. I wanted to figure out the simple circuit but didn't want to assume what an "8E2" was. I'm confident it's a typo, E and R are next to each other on the keyboard.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    I second your suspicion that it is just a typo. I wouldn't be too surprised to discover that there is some convention for using a different letter to indicate different types of resistors, but I've never heard of it and it would have to apply even when a units prefix was available to use as the radix mark.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    8E2 is odd. 8.2 is often 8R2 or 8.2Ω, though devices are so small, the decimal point isn't visible.
  8. KrisBlueNZ
    Member
    Oct 17, 2012
    111
    14
    I've seen E used as R in that way. It was a long time ago, in some European designs. Philips, I think. I never knew the reason behind it.
  9. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I agree with Kris. Both E and R have been used to symbolize "ohms", and it varies from country to country. I'm willing to bet that it's 8.2 ohms.
