89S51 programmer
Discussion in 'Embedded Systems and Microcontrollers' started by diyora, Dec 16, 2007.
  1. diyora
    Dec 16, 2007
    5
    I work on one project in which i control stepper motor through PC.I used microcontroller 89s51.Now i want to make programmer using PC parallel port & communication between microcontroller & pc using USB port.Is it possible ? if yes, then give me an idea about this.
    Thank you.
  2. adventtech
    Member
    Feb 10, 2009
    22
    There is one 89S series USB programmer here .
    Regards
  3. Arm_n_Legs
    Mar 7, 2007
    183
    10
  4. weije1986
    Member
    Apr 19, 2008
    14
    Both circuits need purchasing . Do you guys have any circuit that we can buy from local electronics shop (schematics with component involve) ?
  5. adventtech
    Member
    Feb 10, 2009
    22
    That still will require pirchasing I guess.
  6. rushi53
    Member
    May 8, 2009
    21
    89s51 does not need any external programmer.
    because it contains ISP which means in system programmer
    you need to connect 4 pins of 89s51 to the parallel port.
  7. Hrishi_6032
    Dec 8, 2011
    HI rushikesh can you pls get me the 89S51 programmer schematic & software to dump the program into the contoller as I am new to this area.
    Pls mail me @ Hrishi_6032@yahoo.co.in
  8. jimkeith
    Oct 26, 2011
    539
    99
