89C51 microcontroller Electonic code lock project
Discussion in 'Homework Help' started by micronovice, Feb 12, 2010.
  1. micronovice
    Feb 12, 2010
    6
    Helo all, im new to this forum.
    pLEASE I NEED HELP ME , i am new to microcontroller and even c programing.
    I want to make a project Electronic code lock with LCD and Alarm.
    i am planing to use 89C51 microcontroller,I would like to know were i would start from what is the first thing am suppose to do .plEASE Let me know in time the submission time is close.
    Thanks please please just leave a comment .hep me i dont want to fail.please
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    When's it due? What have you done so far?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Welcome to the forums.
    From your post, I will assume this is for an assignment.
    Searching for code lock projects will surely bring up some items. Here is one out of the projects archive - http://forum.allaboutcircuits.com/showthread.php?t=15030
    You seem to have put this off a bit long. Learning to program plus some electronics will keep you busy for some time.
  4. micronovice
    Feb 12, 2010
    6
    i have not done much, what i have done is just to make research on microcontrollers, i am a big novice in this field but i want to get high marks with the help of you guys. this is how i want my project to work:
    ITwould have the following ,
    LCD.
    MICROCONTROLLER.
    ALARM
    4 X 4 KEYPAD. AND I WANT MY PROGRAMING TO BE IN c LANGUAGE
    FIRST
    DO I NEED TO INTERFACE THE COMPONENTS BEFORE PROGRAMING? OR DO I NEED TO LEARN PROGRAMING FIRST BEFORE I START ANYTHING.
    PLEASE GUIDE ME ALONG WITH THE PROJECT. (hope am not begging to much )
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Surely the school did not simply drop this assignment on you with no preparation.
    what resource have you do draw on? Is there a lab to use? Is there test equipment available. Are there components available to you - power supplies, resistors, capacitors, keyboards, logic IC's, and so on?
    Are you constrained to using some specific microcontroller? Do you have available a programmer for it, and the C compiler?
    I might mention in passing that examples of and the programming for code locks are easy to find. Google turns up 991,000 hits, for instance.
  6. micronovice
    Feb 12, 2010
    6
    @beenthere. i have access to all the materials you have mentioned.(programmer,compiler and others OK
    this is what i have made my research on so far
    i want to use a PIC microcontroller with MPLAB
    i want to use a 4x4 keypad.
    and i want to use an alarm circuit when there is a wrong password. ok thats all. so where do i start from . programing? or where.?
  7. micronovice
    Feb 12, 2010
    6
    again C program and assembley which is easier for a learner... as in for programming microcontrollers
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That may be a matter of personal preference. I like assembler, but many people like C and it's variants.
    With all the example that may be found in the internet, starting your process of learning programming would make sense.
