89C51 Math problem
Uridan
Joined Jun 11, 2009
11
Hi
I am using keil to program my 89C51 using C language, and I am trying to work the following equation.
humidity = (0.6785 * (ADC_value)) - 27.1
note that ADC_value is giving correct values.
But when I build my program it will give me 8 warrnings and when I debug my program the humidity will remain empty, thus the equation is not being implimented within the program.
So I decided to eliminate the Point, at first by using the following equation.
humidity = ((6785 * (ADC_value))/10000) - 27
This time no warrnings were given but when debugging the program a pair of .. will always appear regardless the ADC value. thus again, the equation is not workling properly.
Again, I decided to manipulate the equation for testing and used the following:
humidity = ((6785 * 2)/10000) - 27, but again the value was not right. so I turning the -27 to + 27 and guess what, the equation worked. :confused:
I have no idea what I am doing wrong. Also the keil can work log10(x), sin(x) etc but the program will give some warrnings and will not exectute that part of the program.
I am using the <math.h> library.
Am I missing something important here ?
void sendhumidity_data()
char humidity;
//humidity = (((6785)*(150))/10000)-27;
humidity = ((6785*2)/10000) + 20;
bin=(humidity/10); //select first digit of value converted
bin1= bin + 0x30;
dec = (humidity % 10); //most significant digit
dec1 = dec + 0x30;
SBUF = bin1;
while(TI == 0); //Wait until the serial data is sent.
TI = 0;
SBUF = dec1;
TI = 0;
Note: bin and dec are both unsigned char.
The humidity value should be between 99 - 0 and since I am using hyperterminal I am spliting the hex result in two to display the right ASCII characters from 0 to 9 serially.
Any help would be great please :)
Regards
Uridan
Papabravo
Joined Feb 24, 2006
21,228
I'm not abolutely certain that this is your problem, but unless you have the 8051 doing integer arithmetic with long integers you are probably dealing with overflow
Rich (BB code):
6875 * 150 = 1,031,400 >> 65535 !!
The limit for 16 bit integer arithmetic is 65535. Are you interested in breaking up the problem in such a way that you avoid overflow and other nasty fixed point arithmetic problems? Express 6875/10000 as a quotient of prime factors. Cancel the common terms, and voila, the exact fraction 11/16 is all that is left. Your new equation is
Rich (BB code):
((11 * (adc_value))/16) - 27
for adc_value = 255,
result = 148 which is still bigger than 99
Lets Try 150
result 76
I guess the adc_value must not cover the full range of [0,...,255]
Mark44
Joined Nov 26, 2007
628
That's for unsigned int. If you are using int, the limits are -32768 through 32767. I think that Papabravo hit the nail on the head with his diagnosis of integer overflow.
Uridan
Joined Jun 11, 2009
11
Paperbravo,
Thank you very much!!!, Shame on me for forgetting such an important thing :mad:! /bang head on table
It worked like a charm, I had to modify the serial part a little bit but now the value is being displayed perfectly by using that type of equation.
I was doing another silly mistake, I set the ADC_value to unsigned Char, which holds only 1 bit :p, silly me!
Thanks again Paperbravo I own you one!
Yes regards the ADC_value range, I calculated the formula on a 0.5 difference voltage divider and the maximum output voltage from humidity is 3.7V. So yes I will never reach greater then 99 with that formula.
Regards
uridan
Mark44
Joined Nov 26, 2007
628
I was doing another silly mistake, I set the ADC_value to unsigned Char, which holds only 1 bit , silly me!
I'm pretty sure you meant one byte, or eight bits. That would be it could represent any number in the range 0 through 255.
