8501 Voltmeter
Discussion in 'Homework Help' started by makarandsd, Mar 23, 2011.
  1. makarandsd
    Feb 20, 2011
    13
    I have to make a voltmter using the 8051. I have thought of using the ADC 0808 to digitise analog voltage. Please explain the logic for the program.
    I have the following as mandatory.
    1. 4 7 Segment LED displays.
    Please help
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is a very general statement. You are to use four 7 segment displays. That could indicate 3 1/2 digits (1.999) or something else.
    Is this a straight 8051? If so, it will need an interface IC pluse ROM (for the program) and RAM (for the data) memory IC's.
    At any rate, the A to D converter has to be able to resolve one part in 2000 - that is the 1.999 volts part. An AD808 is only 8 bits, or one part in 256, which is not nearly enough.
    What can your 8051 do? You need to clarify the range of voltages to be able to read, and find an A to D converter that will work with the 8051.
  3. makarandsd
    Feb 20, 2011
    13
    Maximum voltage is 2 volts. I need to display 2 0 0 0 for the maximum. So that isn't a 3 1/2 display.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Reading 2.000 is not too far off 1.999. What about the rest for the hardware?
  5. makarandsd
    Feb 20, 2011
    13
    That would be fine too. I was thinking of multiplexing the displays directly through the controller, only if it is feasible. Otherwise a decoder would work too. But I am stuck at the starting position, how do I put the analog quantity of 2V into the controller. Controller is 8 bit. Will an ADC with more bits help me?
