To start, let me say that this site has given me a wealth of information that i consider irreplaceable. so for that, i say thank you to all that contribute.
I need to construct a standalone 80W, 120V AC to 24V DC power supply for a 1974 Fender Rhodes electric piano. I have already rebuilt it's preamp and am using a purchased power supply but am having tons of problems. I believe my current power supply is in some way causing phasing and/or ground issues with the preamp and makes it go haywire when plugged directly into a speaker. Anyhow, i figure a basic and generic power supply should do the trick. The original equipment is definitely vintage, so that means no ICs.
I found this schematic for a simple power supply:
http://www.aaroncake.net/circuits/supply6.asp
I also found this 80W transformer to use:
http://www.hammondmfg.com/pdf/5c0022-23.pdf
My biggest problem is finding a regulator that will output 24V and handle 3.3A. As far as i can tell, they don't exist. (i could be wrong, and probably am)
Any advice on a good solution? perhaps a different schematic? I'm open to all kinds of ideas. Keep in mind this is an audio application, so clean power is a must!
