8086 Help
Discussion in 'Homework Help' started by CaptinClutch, Nov 15, 2011.
  1. CaptinClutch
    Nov 15, 2011
    Hello everyone, I am having some trouble figuring out this problem..
    Write a program that will generate the following output "your grade is A, B, C, D
    Register AL holds a number between 45&100.
    "A" 90 < AL <100
    "B" 79 < AL <89
  2. CaptinClutch
    Nov 15, 2011
    DATA SEGMENT
    EBCDIC DB 'A'
    DB 'B'
    DB 'C'
    DB 'D'
    ASCII DB '90'
    DB '79'
    DB '69'
    DB '59'
    DATA ENDS
    CODE SEGMENT
    ASSUME DS:DATA,CS:CODE
    GRADE:
    MOV AX, DATA
    MOV DS, AX
    MOV AH,8H
    INT 21H
    LEA DI, EBCDIC
    LEA SI, ASCII
    MOV BX,0H
    again: MOV DL,[DI]
    CMP AL,AL
    JNE HERE
    MOV BL,[SI]
    here:
    INC DI
    INC SI
    LOOP again
    RET
    CODE ENDS
    END GRADE
    END
    Thats what I have so far....
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    Get the breakpoints for the grades.
    Start with grade in AL
    Clear Zero Flag
    Subtract 50 from AL ; Fail
    If Zero Flag is set, Jump to Fail
    Subtract 20 from AL ; 60%+
    If Zero Flag is set, Jump to "D"
    Subtract 10 from AL; 70%+
    If Zero Flag is set Jump to "C"
    Subtract 10 from AL; 80%+
    If Zero Flag is set, Jump to "B"
    Subtract 10from AL; 90%+
    If Zero flag is set, Jump to "A"
    Something along those lines should work, once you get the subtraction correct, though you may want to do bounds checking in the "D" throgh "A" area to subtract the rest of 100 to ensure the answer is Zero in the event a number greater than 100 was input, then display an out of range error.
  4. CaptinClutch
    Nov 15, 2011
    Thanks! I will try that out.
