8086 array offset address
Discussion in 'Programmer's Corner' started by ecjohnny, Feb 6, 2012.
  1. ecjohnny
    Thread Starter Senior Member
    Jul 16, 2005
    142
    Hi
    Can anyone help me with basic 8086 programming. i need to display the offset address of an element in an array. For example address of arr[2], arr[6] etc...
    Here is what i've tried but i got a bunch of "rubbish" on display. It compile fine with no error/warning.
    data segment
    arr db 12,45,34,3 ;examples
    data ends
    code segment
    assume cs:code, ds:data
    start :
    MOV AH, 9
    LEA DX, arr+1 ;display arr[1]???
    INT 21H
    MOV AH, 4CH
    INT 21H
    code ends
    end start
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    INT 21h / AH=9 - output of a string at DS: DX.
    String must be terminated by '$'.
    Code ( (Unknown Language)):
    1.
    2. example:
    3.   [FONT=Terminal][SIZE=3]
    4.      [COLOR=#000064]org[/COLOR] 100h
    5.      [COLOR=#0000FF]mov[/COLOR] [COLOR=#C80000]dx[/COLOR], [COLOR=#000064]offset[/COLOR] msg
    6.      [COLOR=#0000FF]mov[/COLOR] [COLOR=#C80000]ah[/COLOR], 9
    7.      [COLOR=#0000FF]int[/COLOR] 21h
    8.      [COLOR=#0000FF]ret
    9.
    10. [/COLOR] msg [COLOR=#000064]db[/COLOR] [COLOR=#800080]"hello world $"[/COLOR][/SIZE][/FONT]
  3. ecjohnny
    Jul 16, 2005
    142
    i still dont get it:confused:
    am i using the wrong interrupt? should i use ah = 02
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    You have to write a routine to convert the binary into a character format.
  5. ecjohnny
    Jul 16, 2005
    142
    Oh i see.. no wonder i got bunch of funny chars. just to clarify so my offset address is in binary form? or hexadecimal? to convert it to ASCII for display.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    This is always a misunderstanding with someone not in the know.
    Everything is always in binary. Hexadecimal is all smoke and mirrors.
    As my other quote: There are only 10 types of people in this world, those who understand binary and those who don't.
