I am going to make project which is TEMPERATURE MONITOR UNIT and its display on 7-segment display through microcontroller!!!
All is done and I am going to make a C program for microcontroller!!I have to consider three factors while programming..I am goin to control 3 things through microcontroller..
1-ADC(I am using external ADC IC)
2-Motor to drive fan whose speed varies according to the temperature which is sensed through temperature sensor!!
3-Seven segment display for displaying the temperature!!!
So I want to take suggestions from you as to what factors I should keep in mind while programming!!??I 'll also write the modules here once I complete them..
So plz suggest...
So plz suggest...
