8051 Interrupts Question?
Discussion in 'Embedded Systems and Microcontrollers' started by ra1ph, Jan 7, 2012.
  1. ra1ph
    Thread Starter Active Member
    Jan 5, 2010
    31
    I'm looking for a bit of feedback on a problem that I'm working on:
    The question is;
    "Write an 8051 program that uses interrupts to implement an intruder alarm.
    Let sensor be tied to the INTO(p3.2) pin, which is at 0 when an intruder steps on a special mat, and 1 when there is no pressure on the mat.
    The program should write a 1 to P3.0 (ALARM) to turn on an alarm buzzer when an interrupt occurs. The program should keep the alarm on until there is no more pressure on the mat."
    My attempted Answer is:
    ORG 0000H
    SETB EA ;SETTING Interupt enable registrar
    SETB EX0
    MOV TCON,#00H ;Recognising INT0 WHEN LOGIC lOW
    MAIN_LOOP:
    JMP $
    ORG 0003H ;external interupt 0 vector
    SETB P3.0
    JNB P3.2,$
    CLR P3.0
    RET1
    END
    As usual any help greatly appreciated!
  2. jimkeith
    Oct 26, 2011
    539
    99
    First, your initialization cannot be done down in the interrupt address range because it will write over all kinds of stuff--do it like this:
    The only other potential problem I see, is starting it with someone on the mat...
    Hope this is helpful
    ORG 0000h
    jmp init ;get out of here
    SETB P3.0
    JNB P3.2,$
    CLR P3.0
    reti ;you had RET1 which may not work
    org 0030h ;safe place to put remainder of code--got burnt once putting code in the interrupt area
    init: ;initialization
    mov sp,#80h ;default 07h is too low for stack pointer--got burnt here too--prob not an issue with only 1 interrupt
    clr p3.0 ;clear alarm out
    SETB EX0
    MAIN_LOOP:
    JMP $
    ra1ph likes this.
  3. ra1ph
    Jan 5, 2010
    31
    Thanks for this, I have an end of semester exam on the 8051 on Monday morning, so this is a great help. This question has come up in previous years. I'm glad I was not too far off the correct answer.
  4. jimkeith
    Oct 26, 2011
    539
    99
    assembler directives:
    $mod51 ;put this at the beginning of your code to import mnemonics definitions and addresses or $mod52 for the 8052
    I have always used cseg at xxxxh instead of org xxxxh Probably both will assemble OK.
    I do not have an 8051 reference manual handy so check out which bit to set to make int0 edge triggered--if it is not edge triggered, it will lock up attempting to service a continuously low interrupt signal--another way to do it would be to disable the interrupt while servicing the interrupt and then re-enable it when exiting.
    found it
    setb it0 ;int0 is edge triggered--this is hidden in the tcon register or
    mov tcon,#00000001b
  5. ra1ph
    Jan 5, 2010
    31
    Thanks Jim for the follow up,
    So the revised code is
    $mod51
    ORG 0000h ;we have not used cseg before
    SETB P3.0
    JNB P3.2,$
    CLR P3.0
    SETB EX0
    MOV TCON,#01H ;Recognising INT0 when edge triggered
    MAIN_LOOP:
    JMP $
    Just a question on MOV TCON, #00000001b;
    why should this be edged triggered and not set to 00000000b to be triggered when logic level is LOW?
    PS. Weather here in Ireland is very mild around 10degC . Like yourselves we have had a very mild winter unlike last year when temperature reached -9DegC (16F)
  6. jimkeith
    Oct 26, 2011
    539
    99
    Level triggering is often intended for a short pulse--if the interrupt remains low, it will be continuously attempting to service the interrupt--to get around this, the interrupt is generally immediately turned off until the signal returns high
    With edge triggering it can remain low and will not be re-triggered until it goes high and then low again.
    In microcontrollers there are always multiple solutions to problems.
    ra1ph likes this.
