8051 interfacing with thermal printer
Discussion in 'Embedded Systems and Microcontrollers' started by usmanahmed, Sep 9, 2011.
  1. usmanahmed
    Sep 9, 2011
    hi dears!
    i want to interface 8051 to thermal printer (CBM1000) to print small sentences, can any body help me regarding to this?
    .............plz if u can..............
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Hard to say. We need more information. Your is available in Serial, Parallel, & USB. Which one do you have?
    Then you ask questions in this kind of forum. Information is worth its price in gold. It is hard to provide to much information. Always include links to data sheet or documentation. If you have any code or schematics to show include that also. And here I will emphasize on the importance of posting schematics. We will not be able to help unless you provide such information.
    Looking forward to your next post
  3. usmanahmed
    Sep 9, 2011
    thanks sir,
    sir here is serial thermal printer,its info i am attaching.......
    now kindly guide me.......
  4. u5Al3
    Dec 24, 2010
    21
    you need to study about the serial transmission registers setting of 8051....
    download datasheet of 8051 and read the requirements....
    then program your code....
  5. t06afre
    May 11, 2009
    5,939
    1,222
    You will also need a TTL to RS232 level converter. A very common circuit for this is the MAX232 which is also mentioned in your doc file.
    Use Google and search for max232
  6. usmanahmed
    Sep 9, 2011
    Thanks Sir, i did it now the problem is to print image is it possible with this printer by 8051, kindly guide me.......
