8051 Instruction set
Discussion in 'General Electronics Chat' started by vead, Nov 19, 2014.
  1. vead
    Nov 24, 2011
    621
    8
    Hello experts
    5 bit opcode + 3 bit register specification
    7 bit opcode + 1 register specification
    8 bit opcode
    Many ALU can directly access program memory . so they use registers
    · Accumulator register
    · Rn register (R0 to R7)
    · Ram memory
    · Program memory
    · Instruction decoder
    · Program counter
    · ALU (arithmetic and Logic unit)
    · PSW register
    5 bit opcode that allow 32 operations
    7 bit opcode that allow 128 operations
    8 bit opcode that allow 256 operations
    Example
    MOV A, Rn
    11101 n n n
    Source Rn registers
    Destination Accumulator
    Example Mov A,R1
    11101 0 0 0 MOV A, R0 Mov the content of R0 into A
    11101 0 0 1 MOV A, R1 Mov the content of R1 into A
    11101 0 1 0 MOV A, R2 Mov the content of R2 into A
    11101 0 1 1 MOV A, R6 Mov the content of R3 into A
    11101 1 0 0 MOV A, R6 Mov the content of R4 into A
    11101 1 0 1 MOV A, R6 Mov the content of R5 into A
    11101 1 0 1 MOV A, R6 Mov the content of R6 into A
    MOV @Ri, A
    1111011
    Source Accumulator
    Destination register R0 or R1
    11110110 MOV@R0,A
    11110111 MOV @R1, A
    Example: Mov@R1,A
    Mov the content of A to the address in register R1
    8 bit opcode
    MOV A, direct
    11100101 direct
    Source address
    Example :Mov A, 80h
    Mov the data from direct address 80h to register A
    8 bit opcode
    Q I don’t understand whats the use of three different Instruction formmet ?
    Q2 first two formmet, I think they don’t use Instruction decoder ,I think they store data direcly to the respective registers . Last formmet , I think it use Instruction decoder ?
    Q3 If possble anyone please explain how the diifferent instruction execute in different formmet
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    the 8051 was designed to be a very universal processor, there are several commands duplicated, but with slight differences, to accomodate this.
    vead likes this.
  3. Brevor
    Apr 9, 2011
    282
    56
    The 8051 has 255 opcodes, the A5 opcode is not used and listed as "reserved". Over the years there has been much speculation about what the "secret" A5 opcode does.
  4. vead
    Nov 24, 2011
    621
    8
    We write assembly code on assembler like this
    Assembly code
    MOV A, # 4A ; load data 4A into A register
    MOV R1,# 5E ; load the data 5E into R1
    ADD A,R1 ; add the content of R1 into A register
    INC R1 ; increase R1 with 1
    INC A ; increase A with 1
    MOV A,R1 ; move the value of R1 into A register
    Look following way how this assembly code convert in binary form and tell me Is it correct to learn Instruction set of 8051
    Assembly code
    MOV A, # 4A
    Mcahine code
    0000 74 4A
    BINARY CODE
    0000 0000 0000 0000 0111 0100
    0100 1010
    Example
    Memory address Hex code assembly language comments
    0000 74 4A MOV A,#4A ; Load the immediate data into A
    Where 0000 is memory address. 74 is mov A opcode and 4A is operand
    Explationation :
    Processor read Byte from Program memory at the address indicate by program counter
    Example: processor read Byte (0111 0100) which is opcode MOV A
    First processor(cpu) need to read first byte of instruction
    Example 0111 0100 74 first byte
    0100 1010 4A second Byte
    So processor read Byte form program memory at the address 0000 indicate by program counter and Store Data 4A into Accumulator registor
    So program counter increament and its ready for next bytes in program counter
    Ok If next memory address is 0002
    Assembly code
    MOV R1,# 5E
    Mcahine code
    0002 79 5E
    Binary code
    0000 0000 0010 01111 001
    0101 1110
    processor read Byte (0111 0100) which is opcode MOV R1
    So processor read Byte form program memory at the address 0002 indicate by program counter and Store Data 4A into Accumulator registor
    Again program counter increament and its ready for next bytes in program counter
    Ok If next memory address is 0004
    Assembly code
    ADD A,R1
    Machine code
    0004 29
    Binary code
    00000 00000 0100 00101001 (00101rrr)
    0004 74 ADD A,R1 ; Add the content of R1 into A
    So the processor doesn't read any more bytes from program memory; it can start executing the instruction immediately. It knows that it needs to add the contents of the specified register into the accumulator, and it uses the ALU to do this.
    8051 has 8 bit ALU
    The instruction execution logic unit store the current data 4A of Accumulator into the Input of ALU
    And instruction execution logic unit store the current data of R3 into the second input to the ALU
    Then it tells the ALU to perform an addition operation
    and the result appears at the output of the ALU.
    ALU also use pse register toremember carry auxillary carry overflow …
    Then the program counter is incremented to 0005.
    Assembly code
    INC R1
    Machine code
    0005 0B
    Binary code
    0000 0000 0101 00001 001
    The instruction execution logic unit will Increment R1 register
    Increment program counter to next Instruction 0006
    Assembly code
    INC A
    Machine code
    0006 04
    Binary code
    0000 0000 0110 00000100
    The instruction execution logic unit will Increment A register
    Increment program counter to next Instruction 0007
    Assembly code
    MOV A,R1
    Machine code
    0007 E9
    Binary code
    0000 0000 0000 0111 11101001
    Now the code look like in assembly
    Assembly code
    Machine code
    0000 74 4A
    0002 79 5E
    0004 29
    0005 0B
    0006 04
    0007 E9
    Binary code
    Code (Text):
    1.
    2. 0000 0000 0000 0000  0111 0100
    3.
    4.                                                0100 1010
    5. 0000 0000 0000 0010  01111 001
    6.
    7.                                            0101 1110
    8. 0000 0000 0000 0100  00101001
    9. 0000 0000 0000 0101  00001 001
    10. 0000 0000 0000 0110 00000100
    11. 0000 0000 0000 0111 11101001
    12.
    Finally to understand someone
    Assembly code
    0000 74 4A MOV A, # 4A ; load data 4A into A register
    0002 79 5E MOV R1,# 5E ; load the data 5E into R1
    0004 29 ADD A, R1 ; add the content of R1 into A register
    0005 0B INC R1 ; increase R1 with 1
    0006 04 INC A ; increase A with 1
    0007 E9 MOV A,R1 ; move the value of R1 into A register
    Program memory will be following
    Code (Text):
    1.
    2. Memory address opcode operand
    3. 0000  74 4A
    4. 0002  79 5E
    5. 0004  29
    6. 0005  0B
    7. 0006  04
    8. 0007  E9
    9.
    Program counter will be following
    Code (Text):
    1. 0000 0000 0000 0000
    2. 0000 0000 0000 0010
    3. 0000 0000 0000 0100
    4. 0000 0000 0000 0101
    5. 0000 0000 0000 0110
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    some people confuse machine code, assempler, and compler, the assembler and compiler are there just to make it easier for the programmer to write the program and to read a program. the machine language s what the comands actually are to the processer. there are also decompilers and disasemblers to turn machine code back into readable form, although they dont include the comments and labels, only addresses.
  6. vead
    Nov 24, 2011
    621
    8
    In my post I hav explained how assembly code convert in binary
    can you help me to find out which control signal is need in 8051 to activate different signal of ALU
  7. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    If you consider implementations of FAT filesystem, or JPEG decoders on controllers, your questions are fairly irrelevant. The problems here are on the C language level- how it translates into machine instructions is not interesting.
    You'd get old if you dig into the disassembly.
    You are either a genius for binary and internal works of a CPU, and can guess most things, or you arent, in which case I'd recommend just to treat the CPU as black box, and deal with C language problems instead.
    It can be a challenge just to compile a ready-made source, adapt the IO configuration, and wire the SD card as well TFT, finally decode a JPEG. Try a BMP decoder first, perhaps.
  8. vead
    Nov 24, 2011
    621
    8
    I am not asking about software I am asking about hardware
    Look at MOV instruction
    this is two byte instruction
    74= 0111 0100=MOV A 1 byte
    4A= 0100 1010 1bite
    Ok processor read the binary byte from program memory
    To get something from memory called fetching
    ok that means we are taking 0111 0100 byte from memory called fetching
    Data 4A= 0100 1010 store in to A register call execution
    but what is decode unit ?
  9. takao21203
    Apr 28, 2012
    3,578
    463
    Its like if you consider the traffic light circuit of New York, look at a broadway and ask "But what is travel permission".
    One could tell you its individually wired and the roads plastered + signs put up + racks with computers + uplink to control centres.
    It works according to a predefined rule network. Traffic is measured, computations are made, and individual lights are turned on and off.
  10. takao21203
    Apr 28, 2012
    3,578
    463
    Intel has multibyte instructions, simply put.
    Certain opcodes put the CPU in a state where it will expect another byte.
    Is that so difficult to find out yourself? If so, maybe its the wrong job you are trying to learn. It wont get better, it will get worse, as certainly, not all is explained in a way all is included and totally clear.
    Looking for instance at touch button source codes for STM8, with your approach of researching, asking and reasoning, not even "good luck" could be expressed, rather "dont touch it at all".
    I mean, you wont get anywhere if you cant put things together yourself. Not to speak, you wont be a brilliant hardware crackwhiz neither, inventing something new. Or probably you will, because you question things which by now, should be quite obvious to you already?
    Maybe some day this will allow you to see them in a way we dont, make some clever deduction, and win a nobel prize.
    vead likes this.
  11. vead
    Nov 24, 2011
    621
    8
    To understand something complex we should have basic knowledge. so I started to learn basic I am trying to learn hardware of 8051 from the lot of days . If I learn about 8051 then I can start to learn about another controller so thats why asking here. Its batter for me If you can give any advice about how does Instruction fetch decode and execute. ?
  12. takao21203
    Apr 28, 2012
    3,578
    463
    Well sure. I studied the 68000.
    It is indeed a 4bit controller, which runs a microcode, emulating a 16bit Instruction set.
    The first 4 bits are the instruction group.
    Inside the larger CPU, there is a smaller, simpler controller.
    It cycles through a number of states, during it will bridge certain paths, latch certain data, and activate sub-circuits, then it will connected the accumulator for instance to the EA unit, and latch the result, or connect to the register bank, and latch the result.
    Good explanation eh? Inside the controller, there is another, simpler controller, which you dont see, and which instructions set you dont know, so, you dont need to wonder about it.
  13. vead
    Nov 24, 2011
    621
    8
    sorry But I am not getting something related to my question Its batter can you explain with small example ?
  14. cmartinez
    Jan 17, 2007
    3,698
    2,794
    The 8051 "fetches" the code and then executes it in steps synchronous according to its internal clock. Think of the clock as the controller's heartbeat, in which something is executed every time it beats. Take a look at this video, and it will give you a glimpse on how an MCU's internal clock executes instructions. You can think of it as a clock cycle being executed each time a marble is added into the machine.
    In a classic 8051 most instructions usually take 12 clock cycles, while others 24 and others even up to 36. In the most recent 8051 models (such as Atmel's 89LP4052) the cycles per instruction have been minimized to 1, 2 and 3, (maybe even up to 4 clock cycles) depending on the instruction being executed. This results in a far superior execution speed and less power drain.
    vead likes this.
  15. vead
    Nov 24, 2011
    621
    8
    sorry But due to some technical problem I can't see that video but can you help me to With mov instruction
    this is sequence
    0111 0100 opcode
    0100 1010 operand
    Mov A,#4A
    processor read first byte from program memory (fetching )
    data 4A will be store on A register executing
    my question is how does register A know that it need to store data ? decoding
  16. cmartinez
    Jan 17, 2007
    3,698
    2,794
    Not sure what you mean... but the "MOV A, #data" instruction has an encoding of "0111 0100" ... when the MCU finds that encoding during execution, it already understands what it's supposed to do... it's supposed to store the given data into the A register (which is at memory location E0H)... I've attached the 8051 Hardware Manual, which explains in detail all these technicalities, including the standard 8051 memory map, and the complete catalog of standard instructions ... hope that helps...
    absf likes this.
  17. takao21203
    Apr 28, 2012
    3,578
    463
    http://en.wikipedia.org/wiki/Finite-state_machine
    Somehow with your posts you tell the forum you dont know anything about how a CPU works.
    Read up State machine.
    Read up turnstile for GODs sake: http://en.wikipedia.org/wiki/Turnstile
    the turnstile doesnt "know" if you have a ticket, clear?
    Read up http://en.wikipedia.org/wiki/Turing_machine
    Think of a large 3 dimensional turnstile.
    When it gets the MOV byte, it snaps into a position where it will look for a databyte. It doesnt know a thing, and the register has no clue either.
    Its no matter if 8051 or what the binary codes are, thats just trivial, you can ditch it, if you understand it, you dont need the binary codes. And if you dont, they wont help you either.
  18. cmartinez
    Jan 17, 2007
    3,698
    2,794
    I think I'm beginning to understand what your question here is...
    Think of an MCU as an extremely complex network of logic gates, with some that give a direct output, depending of their inputs, (such as AND's, NAND's, OR's, XOR's) and some others that depend on a clock (such as JK flip-flops, and SR latches) etc...
    depending on the encoding of the instruction, this instruction will ALWAYS be channeled through the same series of gates (which could be dozens in a row, or in parallel, and be even nested), that is why, even if you're using the same assembly mnemonic in two similar instructions, such as MOV A, #10D and MOV A, R1, they're actually two different instructions once they're compiled, since one stores a direct value into register A, and the other the contents of R1... although both instructions are similar, they're processed through an entirely different set of pre-assigned logic gates after they're fetched by the MCU
    vead likes this.
  19. kubeek
    Sep 20, 2005
    4,691
    806
    Register A know only that write into it is going to happen.
    I will try to explain the stages of computer cycle:
    Fetch - an instruction is read from memory into decoder
    Decode - control lines are set according to the instructioin
    Exectue - the operation is carried out, i.e. the data is written to reg A in your case.
    These three allways take turn.
    The steps for that instruction:
    1) Fetch 0111 0100 opcode from memory
    2) decode 0111 0100 and see that you need to read the next byte as well
    3) execute - do nothing, you dont have anything to do yet
    4)fetch 0100 1010 operand
    5) decode - do nothing, its not an opcode, so you dont need to decode it
    6) execute - write operand to reg A.
    If the operation was INC A -0000 0100 it would go:
    1) Fetch 0000 01000
    2) decode it and set the control wires to ALU
    3) execute - increment A
    absf and vead like this.
  20. vead
    Nov 24, 2011
    621
    8
    that's ok to execute instruction we need to set control lines or wires
    11101 rrr its 1 byte instruction
    Last three number 001 is control signal that set to register R1
    When last three digit is 001 ,register R1 will be set
    Last three number 010 is control signal that set to register R2
    When last three digit is 001 ,register R2 will be set
    11101 0 1 1 MOV A, 3 Mov the content of R3 into A
    Last three number 011 is control signal that set to register R3
    When last three digit is 011 ,register R3 will be set
    11101 1 0 0 MOV A, R4 Mov the content of R4 into A
    Last three number 100 is control signal that set to register R4
    When last three digit is 100 ,register R4 will be set
    11101 1 0 1 MOV A, R5 Mov the content of R5 into A
    Last three number 101 is control signal that set to register R5
    When last three digit is 101 ,register R5 will be set
    Last three number 101 is control signal that set to register R6
    11101 1 0 1 MOV A, R7 mov the content of R7 into A
    Last three number 010 is control signal that set to register R7
    When last three digit is 101 ,register R7 will be set
    example
    Last three number 000 is control signal that set to register R0
    When that three input will be low , register R0 will be set
    In this example three 000 input wire need to set R0
    Now we have 5 number or wires 11101
    I don’t understanding which number specify the which type of control signal ?
    To set the accumulator it can take 1 ,or 2 or 3 or 5 number or wire
    How to know that which specific number or wire is used by control unit to set accumulator ?
    Ok this instruction contain 8 bit means 8 wire. we have already taken 3 wires to specify the register ,now I have only 5 wires but we have to tell other component don’t do anything during this instruction
    Don’t use alu – need 1 wire to do activate or deactivate
    Don’t increament program counter- need 1 wire to do activate or deactivate
    Don’t use PSW register - need 1 wire to do activate or deactivate
    Don’t use immediate data - need 1 wire to do activate or deactivate
    I think I need more then 8 wire to execute this instruction
    But in this instruction I have only 8 signal so how to set that I need and how to tell other that I don’t need you ?
    Control signal are required inside processor inorder to perform each type of opeartions
    Control unit generate right signal so that the processor can perform requested operation
    how to findout which control signal is required for different operations ?
