8051 Atmel 89C51 programming in C example
Discussion in 'Embedded Systems and Microcontrollers' started by 8051HELP, Nov 27, 2015.
  1. 8051HELP
    Nov 27, 2015
    I need to write only numbers (every second) in string on display (memory mapped on 0x8001 adress) which are divding with 2 .
    I must use counter not delay () for interrupt ...
    Below is code which i imagine but dont work correctly...
    [ CODE ]
    #include <reg51.h>
    #include <math.h>
    typedef unsigned char byte;
    byte a[3]= {2,1,8};
    byte counter, frequency,displ;
    int i=0;
    byte xdata display _at_ 0x8001;
    sbit switcher=P0^0;
    void Inic(void) {
    EA=1;
    ET0=1;
    TMOD=1;
    TH0=0x3C;
    TL0=0xB0;
    TR0=1;
    counter=1;
    frequency=0;
    void timer0(void) interrupt 1 using 2 {
    TR0=0;
    TH0=0x3C;
    TL0=0xB0;
    TR0=1;
    if(switcher) {
    if(!(--counter)) {
    counter=frequency;
    display=displ;
    void main(void) {
    Inic();
    while(1) {
    if(switcher) {
    for (i=0;i<3;i++) {
    if(a/2) {
    displ=a;
    frequency=20;
    [ CODE ]
