8051 (AT89S52) Question
Discussion in 'Embedded Systems and Microcontrollers' started by Dseng, Mar 13, 2016.
  1. Dseng
    Jan 13, 2016
    20
    Since the ports are bit addressable on an 8051, can I make some bits of a port inputs and some bits outputs by writing ones and zeros to them.
    Example:
    Will the following make bits 0,2,4 and 6 of P1 an input and bits 1,3,5 and 7 output bits?
    ORG 030H
    SETB P1.0 ;Make P1.0 an input bit
    CLR P1.1 ;Make P1.1 an output bit
    SETB P1.2 ;MAKE P1.2 AN INPUT BIT
    CLR P1.3 ;MAKE P1.3 AN OUTPUT BIT
    SETB P1.4 ;MAKE P1.4 AN INPUT BIT
    CLR P1.5 ;MAKE P1.5 AN OUTPUT BIT
    SETB P1.6 ;MAKE P1.6 AN INPUT BIT
    SETB P1.7 ;MAKE P1.7 AN OUTPUT BIT
    END
    If the above is true then will the following acomplish the same thing?
    ORG 030H
    MOV P1,#AAH
    END
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    AT89S52 datasheet, please check page 3 - Pin Description.
    Port 0 Port 0 is an 8-bit open drain bi-directional I/O port. As an output port, each pin can sink eight TTL inputs. When 1s are written to port 0 pins, the pins can be used as highimpedance inputs.
    Port 1 Port 1 is an 8-bit bi-directional I/O port with internal pullups. The Port 1 output buffers can sink/source four TTL inputs. When 1s are written to Port 1 pins, they are pulled high by the internal pullups and can be used as inputs. As inputs, Port 1 pins that are externally being pulled low will source current (IIL) because of the internal pullups.
    Do you have any special why not separate two parts as P0~P3 and P4~P7?
  3. Dseng
    Jan 13, 2016
    20
    No, it's just a general question. It could be any ports or any combination. For example could I use six bits on port 2 as inputs at 2 as outputs?
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    Yes, you can do what you want as that
    What I want to emphasize is that before you want to use the input function then you have to send 1(high) to the bit you want to input.
