No, I canned that idea. The problem with measuring "frequency" over 1 second is that the resolution is terrible for low frequencies. So there was little point of having the xtal oven giving perfect timing if the freq being measured was 200Hz with +/- 1Hz error!Roman you are definitely right it would be easier, but not so much fun, and I would probably learn less! I won't discount going that route, but I might have a go at it anyway. I had a quick search for frequency counter kits, and came across an old post of yours at electro-tech online, did you ever build that?
In the end I calibrated my old bench freq meter to a GPS time pulse and got that down to <1PPM error.
A well designed PIC/AVR based frequency meter will measure low frequencies as periods, which makes them a lot more complex to write code for but means that the accuracy and resolution of low frequencies is still good. I have built PIC frequency meters using that system too but have never released the project as there are already lots of good PIC/AVR based frequency meter kits around.
Also for signal generation now I am more often using digitally generated frequencies which make a very accurate and stable frequency. That means I am not reaching for a frequency meter very often these days.
