8 watt audio amplifier
Discussion in 'The Projects Forum' started by InnocentOfTheWorld, Jun 22, 2011.
  1. InnocentOfTheWorld
    Apr 15, 2010
    47
    hello
    how are you all
    i want an efficient design of 8 watt audio amplifier.
    kindly provide me design file in proteus so i can make it on pcb.
    also it should be having noise reduction functionality.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. InnocentOfTheWorld
    Apr 15, 2010
    47
    .i saw a lot of circuits on internet using LM383 and TDA2003. As it is my university project and LM383 is a built in class B amplifier. i don't want to use ic's which are made for these special purposes. i need a design of 8 watt audio amplifier with less noise using MOSFET'S or BJT'S . kindly help me with an efficient design.
    you can mail me at
    <SNIP>
  4. #12
    Nov 30, 2010
    16,705
    7,358
    Are you getting a University education in "How to get other people to design circuits for you"?
  5. InnocentOfTheWorld
    Apr 15, 2010
    47
    for the first time you do anything you will always need some guidance or a teacher @ mr #12
  6. #12
    Nov 30, 2010
    16,705
    7,358
    I think the teacher is included in the university, and is supposed to guide you. However, you can post a schematic of what you have accomplished and describe the points you are having difficulty with. That will probably get you some help.
  7. InnocentOfTheWorld
    Apr 15, 2010
    47
    o.k i post the design wait
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
  9. bertus
    Administrator
    Apr 5, 2008
    15,808
    2,390
  10. KJ6EAD
    Apr 30, 2011
    1,426
    364
    If you just click the given link for the Completed Projects Collection, you get the default 2 weeks depth (no amplifier circuits in that time). To see all history you have to change the setting to "from the beginning". You can also do an advanced search using the keyword "amplifier" and the forum "Completed Projects Collection".
    "Minimus" and "Quatour" seem to be in the right wattage zone but both use specialty audio amplifier ICs.
    InnocentOfTheWorld likes this.
  11. InnocentOfTheWorld
    Apr 15, 2010
    47
    thanks kj6ead actually i want to design it with differential input stage and i think class ab amplifier output stage would be good. but i don't know how to set the different parameters of the circuit
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    Since your teacher is not teaching you then you must learn about audio power amplifier circuits yourself with tutorials or books.
    On my reply to your PM I recommended www.redcircuits.com and Rod Elliot's site where you can simply copy the amplifiers. Didn't you look at them?
    When you copy circuits then you learn nothing and might get into trouble with your teacher.
  13. #12
    Nov 30, 2010
    16,705
    7,358
    Trouble with the teacher? How about trouble with the rest of your life as any kind of electronics worker?
