Hi All,
I'm going to build a control panel for testing a drum motor. The specs are as below:
Interoll 113S 1-phase Drummotor
1) 230 V / 50 hz
2) 6 leads cable
3) 0.11 kW
5) Capacitor run : 6 uf
6) Rated Current : 1.13
i need to test the forward and reverse directions, with using a 8 pin relay :
1) Can someone help me with the circuit diagram between motor and relay ?
2) Any advice for timer for start capacitor?
1) 230 V / 50 hz
2) 6 leads cable
3) 0.11 kW
