8-bit PIC16 Microcontroller C Coding guidelines
sarvanan
Joined Aug 8, 2016
45
Hi Members,
Could anybody please let me know or point to some standard tutorials which says what are the good practices to be adopted while programming 8 bit PIC16 microcontroller in C language?
I need to know this in terms of 8 bit PIC16 programming more than just general C coding guidelines?
Thanks & regards,
Sarvanan.
Robin66
Joined Jan 5, 2016
275
From a performance perspective (EDIT), the best advice I can give you is stay connected with the underlying asssembly ie. always have a pretty good idea of how your C will be compiled into the device's instruction set. In my code this results in:
  1. Avoiding floats; use chars where possible; shorts are ok
  2. Avoid divide (/) operators, and code up my own proxy for it in C
  3. Using bitwise rotate operators (>>, <<) more than you usually would
  4. Use pass by ref. sparingly
  5. Be aware that making the code readable by splitting into functions has a runtime cost
However if you're in the fortunate position to not worry about a few ms lost here or there then disregard this
takao21203
Joined Apr 28, 2012
3,702
Well this is a guideline for optimizing.
You should by all means isolate IO statements to keep your code portable.
Dont use numeric values through the source but use defines
Make use of lookup tables, and remove reundant calculations, especially multiplication and division,
if you need the result multiple times, dont calculate it multiple times.
If you need to multiply with only a few different values, optimize with lookup table and shift operations.
Actually in some cases using a multiplication or division doesnt make a difference but be aware the code size will increase a lot and its very slow
AlbertHall
Joined Jun 4, 2014
12,346
I agree with all that but in many cases it may be better and easier to use floating point maths if:
1. There is enough space in flash for the code.
2. If the time it takes does not compromise the code.
Using floats can make the code much clearer and easier to understand, especially when you come back to it after some time.
So avoid floats where you need to, but don't sweat it if you don't need to.
Robin66
Joined Jan 5, 2016
275
I agree with all that but in many cases it may be better and easier...
Bang on, I've modified my original post. I'm down a rabbit hole at the moment where runtime performance is critical and I keep getting caught off-guard by 1000s of instructions lost on seemingly simple operations.
NorthGuy
Joined Jun 28, 2014
611
... what are the good practices to be adopted while programming 8 bit PIC16 microcontroller in C language?
Same as with any other programming - think before you do, know what you're doing, be creative, program in small increments, take responsibility for your actions, etc.
JohnInTX
Joined Jun 26, 2012
4,787
Keep in mind that C does not fully insulate you from the underlying PIC architecture requiring that you know something about that. A couple of examples I can think of :
RAM is limited and broken up into banks. That usually means limits on array sizes, buffers etc. requiring that any single array be able to fit into the 80 or so bytes in one bank, even if you have RAM available in other banks.
RAM and ROM need different instructions to access data. Structs/strings etc. of the same type are frequently stored in both. Some compilers use run-time tests to generate code to get that data and keep a light footprint. Others like MikroC ver 6, read the constant data from ROM to RAM at startup severely limiting the amount of constant data you can have.
In short, C can be useful tool but you still have to know the underlying PIC hardware very well to avoid problems.
Use a device with more than needed memory/speed resources at first. This allows you to concentrate on good data structure/algorithm design and good implementations of those structures and algorithms. After it works then try to optimize for speed and space.
Readability is king!
Learn to use (from the hardware point of view) the structured 'goto' (switch) in C and don't be afraid to use a plain 'goto' for fatal error handling in nested functions or modules to a single label. Typically the implicit/global processor state gets manipulated at this level so you want the program state to closely mirror that at a low level. This means things like designing data structures that are a binary match for peripheral device registers so they can be easily manipulated and passed with structure pointers. Use global variables sparingly but because of memory limitations the use of 'static' variables in functions is sometimes a good idea in non-nested functions.
http://embeddedgurus.com/barr-code/2011/08/dont-follow-these-5-dangerous-coding-standard-rules/
8-bit 'integral promotion' in XC8 is not your friend when you need to do strict 8-bit math tricks (non-portable hacks) for speed.
http://www.microchip.com/stellent/groups/sitecomm_sg/documents/devicedoc/en555854.pdf
Because 8-bit controllers are usually directly involved with I/O devices and simple hardware interrupts our friend the volatile keyword in C is important. Atomic operations are usually at the 8-bit level so 16-bit integer values can change mid-evaluation when volatile if they are not protected with memory barriers (like disabling interrupts during some operations and re-enabling them later, double reads, buffers or etc ...).
sarvanan
Joined Aug 8, 2016
45
Thanks a lot to all of you who responded to my query.
I got enough information. Thanks again.
With best regards,
Sarvanan.
John P
Joined Oct 14, 2008
2,026
If that's an issue, plan on skimming through the list file looking for lines of C that compile into outrageous amounts of assembly code. You may be able to rewrite the C instructions to encourage the compiler to be more efficient, or perhaps you'd want to put in a block of assembly instructions. It's another argument for having some understanding of how the processor works.
