8 bit Parallel in Serial Out
Discussion in 'The Projects Forum' started by spitty19, Apr 5, 2015.
  1. spitty19
    Apr 5, 2015
    11
    I am trying to create a laser communication system using a 8x8 BJT the BJT is coming from a 3x8 decoder and it working properly, but I have never really worked with a shift register before and am looking for some help and or insight on my situation. I don't know If I am using the correct shift register or not but I have attached an image of what I am working on right now and where I am at.
  2. MrChips
    Oct 2, 2009
    12,657
    3,461
    What is an 8x8 BJT?
    8-bit shift registers are available.
    You have to decide if you want:
    serial-in/parallel-out such as 74HC595
    or
    parallel-in/serial-out such as 74HC165
    spitty19 likes this.
  3. spitty19
    Apr 5, 2015
    11
    My apologies I thought I said it in my original post I want the parallel in serial out. and what is the difference from those to the SHIFT_8PIN that I am using in my project now as seen in the picture? Like I said I am pretty new to the shift register game haha
  4. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    You could also look at one of the USART/UART IC's, there have been quite a few in the past, I believe the Maxim MAX3100 series will do it.
    Max.
  5. crutschow
    Mar 14, 2008
    13,529
    3,393
    A USART/UART, as Max suggested, has built-in synchronism for the transmitter and receiver of the parallel-serial-parallel data at each end, which a standard shift-register does not.
  6. spitty19
    Apr 5, 2015
    11
    is that available in multisim, I guess I should expressed that initially that I am performing everything on multisim until the output from my shift register, id like to stick with the 74HC165 as Mrchips had suggested if possible, as once I get it working in multisim I believe I have some of those readily available
  7. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    Presumably if you have a parallel to serial data transmission, there is some kind of protocol decoding to be done on the receiving end?
    Max.
  8. spitty19
    Apr 5, 2015
    11
    Yes that is where the laser communication comes in, im going to use a laser to take the data from the shift register and project it into a photodiode, and then from the photo diode its going to be put into an audio jack and then from the audio jack its going to be brought back into a computer and deciphered using an morse code reader, but I need to figure out how to get the shift register working to be able to do that.
  9. MrCarlos
    Jan 2, 2010
    400
    134
    Hello spitty19
    And Yes: What is an 8x8 BJT?
    The differences between the ones mentioned by MrChips (74HC595 & 74HC165) and the one You are using (SHIFT_8PIN) are similar at the differences between the colors black y white.
    You need a IC identification number NOT its name.
    never will find, in the market, one SHIFT_8PIN.
    So: what is the identification number for your SHIFT_8PIN that you are using in your design ??.
    Also: I Can't see the name of the PINS on the picture you have attached.
    Could You please do a better job about?
    You could use, for your design, the 74HC165, its name is PISO (Parallel IN. Serial OUT). Very similar to your SHIFT_8PIN.
    (Attached Data Sheet).
    In the future You can find, practically, any data sheet in this link:
    http://www.alldatasheet.com/
  10. spitty19
    Apr 5, 2015
    11
    an 8x8 BJT ROM its used along with the 3 decoder to produce a desired output based on the 3 bit input your bring into the decoder based on diorthogonal coding.
    Nevertheless I have attached another image of my shift register hook up but I know I have it wrong as I am not getting any sort of output on my oscilloscope.
  11. spitty19
    Apr 5, 2015
    11
    I understand everything about how it shifts everything along through the shift register I just don't understand how you hook up the CLK, ~CLR, INH, ~SH/LD, SER, and ~QH
  12. MrCarlos
    Jan 2, 2010
    400
    134
    Hello spitty19
    Let me tell you a much of things:
    The 74HC165 has both characteristics: PISO & SISO.
    You are trying to use It as PISO, Parallel-IN, Serial-OUT.
    In order to use that way you must:
    Load the parallel data in the internal registers.
    - Setup the data in all the D's inputs.
    - Apply a negative transition pulse at PIN 1 (Shift/Load'). This PIN in standby must be High.
    - Make false the PIN 15 (Inhibit). Low.
    - Apply 8 positive transition pulses at PIN 2 (Clock).
    All data on the D inputs should appear in its output QH(9).
    The PIN 7 is only the complement of PIN 9.
    absf likes this.
  13. spitty19
    Apr 5, 2015
    11
    How would you go by doing the negative pulse to PIN 1 should you just insert some sort of a switch?
  14. MrCarlos
    Jan 2, 2010
    400
    134
    Hello spitty19
    Well, You can use a Switch or one button or a signal coming from x.
    I think You are missing something: The receiving end must know that Data are arriving. This means "To synchronize".
    Let me call, to the data You are sending as: string.
    How, the receiving end, knows, that a string of data is arriving ?.
    How determine the beginning and the end of such string.
    Should exist something named Protocol.
    - hey, I am going to send some data.
    - Ok send me those, I ready to receive.
    - Well, Going there.
    - Have received 8 BITs, it is ok?
    - Yes.
    Let us see your full project, if possible, in order no guessing.
  15. djsfantasi
    Apr 11, 2010
    2,917
    881
    What is diorthogonal coding? Google doesn't have anything for it.
  16. spitty19
    Apr 5, 2015
    11
    my apologies, biorthogonal coding
  17. djsfantasi
    Apr 11, 2010
    2,917
    881
    Ok, thanks. I'm out.
  18. MrCarlos
    Jan 2, 2010
    400
    134
    Hello spitty19
    keep in view the attached document.
    Because You are novice:
    Let's talk a little about the 74LS165 Parallel-in/serial-out 8-Bit Shift Register.
    As You can see by it's symbol, it has 8 Data BIT's inputs, D0(11), D1(12), D2(13), D3(14), D4(3), D5(4), D6(5), D7(6).
    Through those PIN’s You program the data to be send.
    Note, also, that this IC has another PIN SI(10); with this make its function SISO(Serial-IN/Serial-OUT).
    Now: The PIN named SH/LD'(1) has double Function:
    LD' Load the data on its PIN’s Dx(x) into its internal registers. True: LOW level.
    SH Shift The data in its internal registers. True: HIGH level.
    CLK(2) At each positive transition of the pulse applied to this PIN, the data in the internal registers will be Shifted, and will be appearing at its output SO(9).
    Furthermore the input named INH(15) INHibit, precisely, the full Function of this IC. True: HIGH level.
    Now The outputs:
    It has two: SO(9) and QH'(7).
    Through SO(9), The Data entered by Dx(x) or SI(19) Inputs, will coming out serially.
    One after the other.
    As I mentioned earlier QH'(7) is just the complement of the logic state of S0(9).
    The numbers in parentheses indicate PIN number.
    All this wording are in the data sheet in message #9. And More.
    Have You studied those data sheets?.
    In order to practice, you can assemble the circuit appearing in the attached document in Your Multisim simulator. Play with it by a while.
    I Hope that helps a bit.
  19. spitty19
    Apr 5, 2015
    11
    Sorry for the delay , but this is the 8 bit that I was to bring into the shift register and portray out the serial data. As I had said the btw is working correctly and I have the laser part working correctly, I just need to finish it with the shift register.
  20. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Nice one which type laser you mean??
