i need to make a circuit that can convert 8bit number system.
we should be able to choose what base is your input, and give the value of your input using numeric keypad. then it will display the outputs in 7 segment common cathode for decimal, octal and hexadecimal and LED for binary.
pls help me what IC should b used.. and how to use that IC
