8 bit multiplier ic...?
Discussion in 'Electronics Resources' started by wire, Jan 13, 2012.
  1. wire
    Dec 18, 2011
    13
    I need a 8 bit multiplier IC number and its pin congiguration .Please inform me soon as possible.
  2. DickCappels
    Aug 21, 2008
    2,774
    671
    I think a better description of your needs will help. Is this an 8x8 digital multiplier, an 8 bit x analog multiplier, or an analog multiplier capable of 8 bit accuracy? Or something else?
  3. wire
    Dec 18, 2011
    13
    it is a 8x 8 multiplier digital one
  4. MrChips
    Oct 2, 2009
    12,636
    3,454
    I think there was an Intel 8087.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The easiest way to make an 8 x 8 digital multiplier is with two 64K ROMS each having an 8 bit output. The 16 address lines are the inputs and the 16 data lines (8 on each chip) are the outputs. Piece 'o cake.
