Objective:
To implement a 0-69 counter that counts 0, 1, , 68, 69 and then repeats the cycle by using two 74x163s in LogicWork 4.
Instructions:
For this assignment, you are required to wire two 74x163 counters in a cascade fashion to implement the 0-69 counter. The state of the counter is to be displayed by two seven-segment display devices. The implementation is to be made by using LogicWork 4, where the default parameters of clock, gates, and 74x163 counter should be used.
I know how to use LogicWork. That isn't the issue here. My issue is the implementation. I have the counter running correctly; there are eight outputs that represent a binary number, starting at 00000000 up to 01000101 and then restarting at 00000000.
Getting them to display correctly on the 7-segment displays is the tricky part. You see, I'm also told that I must use two 74x49's (immediately before the two 7-segment displays) that translate a 4-bit binary number that then causes the correct segments of the display to light up. For example, 0000 displays 0, 0001 displays 1, 0010 displays 2, etc.
Now, I can't connect the 8 outputs of the counter directly into the two 4-bit inputs of the two separate display sections (the 4 lower to one and the 4 higher to the other). Once the lower 4 bits reach 1001, they continue on 1010, 1011, etc. The displays, though, can't light up anything past 9 correctly.
So, then, what can I throw in between the 8-bit binary outputs and the two 4-bit inputs of the 74x49's so that the both the counter outputs from 0 to 69 (in binary) correctly and the displays count (in decimal) along with it?
I apologize for the lack of pictures; some screenshots would have made describing my issue so much easier, but I don't have LogicWork on the computer from which I'm posting.
Instructions:
