8-bit binary up counter issue!!
Discussion in 'The Projects Forum' started by saad.zafar01, Dec 19, 2012.
  1. saad.zafar01
    Dec 15, 2012
    19
    How can I limit a 8-bit binary up counter to count upto 215 instead of 256??
  2. tshuck
    Oct 18, 2012
    3,531
    675
    I've never seen an 8-bit counter count to 256:confused:
    Anyway, you'd need to add external logic to clear/load the counter with 0 once the count is 215... or maybe you mean 214?
  3. saad.zafar01
    Dec 15, 2012
    19
    yeah sorry 8 bit counters count upto 255 and i need to limit it to 215
  4. absf
    Dec 29, 2010
    1,493
    374
    215 = 11010111 binary
    May be this would work....
    Get a 6 input NAND gate and connect Q7,Q6,Q4,Q2,Q1,Q0 to the inputs, output goes to the "Reset" of counter. If there is no reset pin, use PL pin and set the Preset inputs to "00000000". If you need 215 to show and only reset at 216 the use "11011000" to reset.
    Allen
    saad.zafar01 likes this.
  5. ScottWang
    Aug 23, 2012
    4,930
    777
  6. saad.zafar01
    Dec 15, 2012
    19
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    In general, be careful about playing this trick. The output of the NAND will go LO for four different input values (sixteen in the case of using 216). Since the one you want is the smallest of them and since you assume that the counter will be coming up from zero, it will work in this case. But don't put it in your bag of tricks as a general way to trap a particular value.
    absf likes this.
  8. saad.zafar01
    Dec 15, 2012
    19
    will the counter count automatically on power & by clock signal or i have to input any data???
  9. absf
    Dec 29, 2010
    1,493
    374
    I dont quite get it.:confused:
    For "11010111" what are the 4 preset values that would make this scheme fail?
    I dint know about this before...:rolleyes:
    Hmm... two of them are "11011111", "11110111", right?
    Thanks.
    Allen
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    It will power up in a random state. It will count up from that state (in response to the clock) until it either rolls over or satisfies the conditions you've established to automatically reset. If that initial behavior is not acceptable, then you will need to include circuitry to effect a power-on-reset to force it to initialize the way you want it to.
  11. WBahn
    Mar 31, 2012
    18,087
    4,917
    Sure.
    If you are only looking at the bits that will be HI, then you have turned all of the other bits into "don't cares".
    So the NAND gate will go LO for the following states:
    11010111 = 215
    11011111 = 223
    11110111 = 247
    11111111 = 255
    absf likes this.
  12. absf
    Dec 29, 2010
    1,493
    374
    If you're using 4020 or 4040 as suggested by ScottWang, you dont have to set any input. The counters than I was describing was binary counter like 74163 or 74193 that has presetable inputs.
    But you can make a power-up reset for your cmos counter to make sure that it starts with zero. Just use a 1uF cap and a 10K resistor should be fine.
    Allen
  13. saad.zafar01
    Dec 15, 2012
    19
    can you give me an alternative for MC10e016 as i cannot find it anywhere....
    i want a 8 bit synchronous binary up counter.........
    i want a urgent reply plz
  14. ScottWang
    Aug 23, 2012
    4,930
    777
    Unless you have some other functions needed, otherwise when you use MC10e016, it will bring you to get more questions.
    MC10e016 datasheet:
    http://pdf1.alldatasheet.com/datasheet-pdf/view/11779/ONSEMI/MC10E016.html
    The simply up counter that you can use CD4520, CD4040.
    CD4520 datasheet,CMOS Dual Up Counters:
    http://www.datasheetcatalog.org/datasheets/120/109587_DS.pdf
    square wave generator : NE555 or 4Mhz Xtal module
    square wave → up counter → DAC.
    The square wave can be divide by CD4520 or CD4040 or 74HC390 to reduce the frequency down to the speed to suit your need.
  15. saad.zafar01
    Dec 15, 2012
    19
    if i use this cmos cd4520 with the rest of my circuit that uses ttl ics will it create problems for me?
  16. ScottWang
    Aug 23, 2012
    4,930
    777
    When you use CMOS to TTL, almost just direct to use it, but if you use TTL to CMOS, usually you need a pull up resistor between them.
    74HCxx and 74HCT and TTL Series Related Application Details. 74HCxx and 74HCT and TTL Series Related Application Details.
    http://thebestclub.freebbs.tw/viewthread.php?tid=306&extra=page=1
  17. saad.zafar01
    Dec 15, 2012
    19
    please tell me a 8 bit binary up counter or tell me how to use two 4 bit binary up counters in series
  18. ScottWang
    Aug 23, 2012
    4,930
    777
  19. saad.zafar01
    Dec 15, 2012
    19
    im now using two dm74ls193n to connect them together do i have to connect pin 12 of one to pin 13 of the second?? or pin 12 of one to clock of 2nd... and for stopping the counter at 215 instead of letting it go to 255 shouldnt i be using a and gate instead of a nand gate as the clear pin works at logic 1??
  20. MrChips
    Oct 2, 2009
    12,635
    3,454
    The same thoughts crossed my mind as soon as I saw Allen's solution.
    I would have though that you must include the 0 bits also.
    Thinking about it more carefully, it appears that the solution is valid so long as you are counting up from zero.
    absf likes this.
