Replacements for what? Sharing the original A/D manufacturer and p/n will save about 50 messages.and analog replacments are not available any more.
Separate from that, any discussion about a replacement (part or circuit) needs a buttload of details about available power, speed, number of input channels, noise environment, source impedance, output data format,,,,,,.
Finally, expand your search. 8-bit devices may not be available, but 10-bit and 12-bit devices are. The 12-bit AD7880 can be configured with an internal 2:1 attenuator, so it can handle 10 V signals with a 5 V supply. Texas Instruments has former National Semiconductor and Burr Brown 8 and 12 bit parts with direct ++/-10V inputs.
ak
Yes im still having problems. Clock is for the adc clock input, -15 volt supply gets knocked down to -10 volts and is the ref voltage. 5v is for ic vddYour discussion is very disjointed and it's hard to follow what you are doing.
What's the function of the 555 in generating 60Hz?
What are the ±15V supplies powering?
Do you still have a problem?
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
