8-0-8 TRANSFORMER necessary for modified sine-wave
Discussion in 'General Electronics Chat' started by adeel, Jul 31, 2008.
  1. adeel
    Jun 28, 2008
    16
    hi . friends
    i want to make an inverter which will give modified sine-wave but when i research i found that only 8-0-8 or 10-0-10 volts transformer can give modified sine-wave . i want to use 12-0-12 volts transformer . for this purpose . i think if i increase the 220 volts winding of transformer i can get required volts . am i rite . please help me . thank.
  2. scubasteve_911
    Dec 27, 2007
    1,202
    Modified sine wave? Please explain.
    Are you using DC to create an 'inverter' / AC signal generator?
    You need to explain your intentions better.
    Steve
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    A modified sinewave inverter has a waveform like a square-wave but with a higher voltage step at each halfwave. So the peak of the step is the same voltage as the peak of a sinewave.
    As I told him on another website, the transformer must have the correct ratio to produce the correct RMS output voltage.
    A 12V-0V-12V transformer is used with Mosfets to produce a simple square-wave inverter. The peak voltage of a square-wave is the same as its RMS voltage.
    If a 12V-0V-12V transformer is used with a modified sinewave inverter circuit then the RMS output voltage will be about 0.707 times too low.
  4. scubasteve_911
    Dec 27, 2007
    1,202
    Ohh, gotcha, I thought it was some sort of flyback topology..
    Steve
