7812+ regulator problem
Discussion in 'General Electronics Chat' started by 1-3-2-4, Jun 3, 2013.
  1. 1-3-2-4
    Thread Starter Active Member
    Dec 26, 2008
    194
    I think I have a problem with a new regulator.. between pins 1 & 2 I'm showing continuity should that be right? My power supply keeps going into protection mode.
    Pin 1 is (+) Pin 2 is (-) and 3 is the output
  2. kubeek
    Sep 20, 2005
    4,688
    806
    No there should not be continuity between any pins. There should be a diode from output to input IIRC, check the internal diagram of it.
  3. 1-3-2-4
    Dec 26, 2008
    194
    Not seeing a diode it's a LM7812C
  4. kubeek
    Sep 20, 2005
    4,688
    806
  5. 1-3-2-4
    Dec 26, 2008
    194
  6. 1-3-2-4
    Dec 26, 2008
    194
    OK it turned out to be my PCB I did not notice in a row they were all connected..
    Ok so I separated them but I have a new problem.. my supply voltage for testing is 13.4v and after a few seconds the regulator gets too hot to touch, no load just straight voltage regulation, what could cause that?
  7. tracecom
    Apr 16, 2010
    3,878
    1,396
    It's dissipating too much power. To help with that, you can 1. reduce the load, 2. decrease the input voltage, 3. add a heat sink, 4. add a fan. However, all this may be worthless if your circuit is wrong.
    Post a schematic.
  8. 1-3-2-4
    Dec 26, 2008
    194
    No I found the issue.. I have no load at all and input voltage is 13.4V on a 12V regulator.. that's not much heat at all..
    Nevertheless the regulator must be oscillating my wire length is 10 inches long and I don't have a 0.1uF cap on the regulator.
    Just turning it on with nothing connected to the IC socket it's heats up to shutdown temp within a few min.
  9. tracecom
    Apr 16, 2010
    3,878
    1,396
    Post a schematic.
  10. Shagas
    May 13, 2013
    802
    74
    Continuity between pins is usually a sign of a short in the ic , meaning you either accidentally screwed it up when first connecting it or maybe they just gave you a defective one. Or maybe it was damaged by very high static (if that's possible with this IC)
