7812 gets hot. how to reduce the current.
Discussion in 'General Electronics Chat' started by imraneesa, Jun 8, 2015.
  1. imraneesa
    Dec 18, 2014
    189
    i tried to connect 7812 to laptop charger 19V 3.5A. and the wire start to smoke. 3.5A is too much for the regulator?
    how to limit it? it is not possible to put resistor in series becoz we need so much wattage.
    what alternate things i can do.
    i have checked the pinouts in datasheet. so i connected them correct.
    do so much current passes through regulator even though no load is connected?
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    It's hard to understand your results. It sounds like the regulator got hot with no load attached?
    Did you use input and output capacitors as recommended in the data sheets? The ripple in the supply voltage may have been causing problems for the regulator. Filtering it may help.
    The normal 7812 cannot handle 3.5A, even with a large heat sink. The application circuits in the dat sheet will usually describe how to build a higher current circuit.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,375
    651
    Are you saying that the charger wire started to smoke? Was there a load on the 7812 at the time?
    Yes. Maximum current tolerated depends on package and heatsink.
    Determine what is drawing so much current and go from there.
    Quiescent current for a 7812 should be around 10mA.
  4. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    What causes the LM7812 to get very hot is when there is a large voltage across it at that current. You have 19 volts in, and 12 volts out, so that means there are (19 - 12 = 7) volts across the regulator. At 3.5 amps, that's (7 * 3.5) = 24.5 watts, the same as a small soldering iron.
    If you need 12 volts at 3.5 amps, your best bet is to buy a ready-made adapter with that output on eBay or somewhere. It won't be very expensive. Second choice, if I was doing it, would be to buy a switching regulator on eBay, perhaps based on the LM2596, and put a big heat sink on the actual regulator part. Last time I got one of those modules, it was less than $3 from eBay.
  5. imraneesa
    Dec 18, 2014
    189
    Thank you for all the comments. i went to recheck and found how stupid i was. i connected hot wire to ground and ground to input.
    i spoiled the regulator finally. but i learned something. thank you so much everybody.
  6. imraneesa
    Dec 18, 2014
    189
    what is quiescent current mean. can you please explain it in easy words? thank you.
  7. OBW0549
    Mar 2, 2015
    1,389
    932
    Quiescent current is simply the idle current: the current the internal regulator circuits take for their own operation, regardless of load current.
  8. kubeek
    Sep 20, 2005
    4,686
    805
    There is no better experience than letting the magic smoke escape. You won´t do that same mistake anytime soon.
  9. ian field
    Oct 27, 2012
    4,447
    791
    The 78xx appnotes describe how to add an external bypass transistor to get more current - its been discussed several time just recently on this forum.
    If you're burning up wires, you have a short somewhere.
  10. dl324
    Mar 30, 2015
    3,375
    651
    I used the terminology used by the manufacturer. Quiescent == inactive or idle. Quiescent current changes depending on the regulator's load. That is important to know if you're inserting a resistance or diode in the ground connection to change the output voltage. See specs attached below.
  11. ian field
    Oct 27, 2012
    4,447
    791
    I couldn't find the bit in the manufacturer's literature about the wires started to smoke.
