7805 voltage regulator question
Discussion in 'The Projects Forum' started by alexx, Aug 21, 2011.
  1. alexx
    May 29, 2011
    29
    hello!
    I made a volt regulator using a standard 9V battery, a 0.22 uF mylar cap on the input, and a 0.1 uF ceramic cap on the output. This gives me an output voltage of 4.96V BUT i need it to be 5.05V because the 4.96V is not powering my device (no, the device isn't broken). my question is : can i replace the .22 uF cap with a different cap to increase the voltage a little?
    thanks!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Pardon my incredulity. Surely 90mV doesn't make that much difference. The regulated output is a function of the 7805's internal electronics - not the capacitor values.
  3. alexx
    May 29, 2011
    29
    thanks for the response,
    I thought that too, so i ran 5.05V to the device to see if it was broken but it worked :S and then again ran 4.96V to the device (from the regulator) and it didnt work
    by changing the 0.22 uF cap to a smaller cap would it make for a smaller voltage drop through the circuit resulting in a higher output voltage?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Having aroused my curiosity you might divulge some additional info on the nature / type of device you are testing.
    Sounds close to broke to me if it's a commercial electronic device.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    A 7805 sources about 5.5mA via it's GND pin; so if you place about 16.3 Ohms between the 7805's ground pin and GND, you'll increase the output to 5.05v.
    However, it's more likely that your load is heavy enough to cause your 9v battery's output voltage to drop when you try to power it.
    alexx likes this.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    No it wouldn't. The capacitor is a shunt component - not a series component. If a mylar cap was in series with the regulator you wouldn't get any output at all, since good capacitors block DC. You seem not to have a clear grasp on the nature of capacitors and their role in this application.
    The 7805 will have a typical output variation of 4.8 to 5.2V - due primarily to manufacturing tolerances.
    alexx likes this.
  7. wayneh
    Sep 9, 2010
    12,368
    3,224
    +1
    Explains everything.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Agreed, it's the most likely explanation. Depends if the OP measured the regulator output voltage with the load connected or not.
  9. alexx
    May 29, 2011
    29
    oh okay so changing the cap wouldnt help, thanks
    so will adding the resistor work? or do i need to add a resistor and increase the voltage supply too
  10. alexx
    May 29, 2011
    29
    I measured it without the load
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If your battery cannot source enough current to keep the regulators' input above ~7v, then the regulator output voltage will drop regardless of how much resistance you place between the ground terminal and GND.
    9v batteries have very limited output capacity. When fresh, you can actually get more than an ampere of current from them; but that lasts only a few moments.
  12. alexx
    May 29, 2011
    29
    okay, so a resistor is probably not needed. I will try making the current source greater by changing the 9V to 18 V, and then power the device
    thanks!
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What IS the device?
    If you try to use a couple of 9v batteries in series to power the 7805, then (18v-5v) * current = Watts of power wasted in the regulator, and 5v * current = Watts of power used in your device. This means that your circuit will be less than 38.5% efficient.
  14. alexx
    May 29, 2011
    29
    the device is a viewfinder from an old sony video camera. and the old camera supplys the viewfinder with 5.05 V (measured with out viewfinder attached) and 0.13 A (measured in series with viewfinder)
    so i am matching these values using the regulator. my regulator gave me 4.96 V, and with a 47 ohm resistor folowing the positive output of the regulator, gave me 0.11 amps. but this did not power the viewfinder
  15. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    130mA is much too much of a load for a 9v battery to power for very long.
    You would be much better off to use four AA NiCD or NiMH batteries without a regulator.
    alexx likes this.
  16. atferrari
    Jan 6, 2004
    2,663
    783
    Are you able to handle the viewfinder completely separated from the camera?
  17. wayneh
    Sep 9, 2010
    12,368
    3,224
    Then you should try wookie's suggestion, and perhaps test other 7805s as they might vary slightly, but enough.
    Oops, nevermind, didn't see page 2
    alexx likes this.
  18. alexx
    May 29, 2011
    29
    what do you mean handle? i still have to figure out how to connect the viewfinder, after i power it, to an alternate video camera (a much smaller one, like a pinhole camera but not as expensive). so i guess the answer would be no i dont know how to handle it/operate it seperated from the viewfinder. all i expect is a blue screen on the viewfinder right now, then i will attemp to solve the video part
    another interesting note: when i measured the voltage being supplied by the sony camera to the viewfinder, with the viewfinder attached/with load, the multimeter went up to a steady 5.12 V , and current stayed 0.13 A
    also: i tried adding a 22 ohm resistor after the ground pin of the 7805 like sgtwookie said, and the output voltage went up to 5.07 V. so cool! BUT a regulated 5.07 V with and 18 V power supply and a current of 0.11 A still didnt power the viewfinder :(
